help with nitrous and th400
BTLFEDSS
N/A dyno last year was 479rwhp/534tq
With a 200shot I only gained 130 or so it said
I think I was blowin through the converter on the dyno cause it def feels like a 200shot at the track
Few ideas to toss out...random ideas
1. keep in mind that th400/stall eats up more than you think
2. what tires where you dynoing with (size matters)
3. A/F
4. Enough fuel
5. Compression
6. Full bottle/purged/heated properly
7. what cam are you running, might need to change it up
8. What RPM does it activate/deactivate; spraying though shifts i assume
9. Screw it and put some bigger pills in
10. What motor are ya runnin, tune?
11. Toss some TR8's in there
12. I wish it wasn't snowing
but with a 150 blast and a TH400, those numbers seem about right
Let us know boss
Can be lots of things, tune, camshaft, exh system, exh port, converter, trans etc etc. A decently working engine that size on 150 hit Id expect around 600 rwhp, maybe a little less
NO. Make it work. The fact that your 150 hit is making 43lb-ft at the tire means there is something big time wrong. You should pull 5-6 degrees, not 2. It would have been a long day of tuning if that was my car. A quicker burning flame wants less lead to make max power. Check your jets and solenoids again. I really hope your trans/converter aren't damaged. Check the fluid level? Is that a Yank SS3600? If so that shouldn't be an issue.
Next year I am putting a edelbrock plate kit on it, I got it used off this site cheap. I will be spraying 150 to 200 through it. But I'm running all motor the first year to get everything down pat on the car first.
LSA aint a magic number, and your motor has no idea what lsa your cam is. Have seen 250 rwhp on a "225' shot on a 112 lsa camshaft.
the cam may or may not be right, but its not the lsa's "fault"
Everyone has an opinion your running too much overlap for that size shot.
The cam I did for the car that won last years pump gas drags has more overlap than that. 9.0s at 3600 lbs on double the nitrous, Take it for what its worth. Last edited by GrannySShifting; Mar 25, 2008 at 05:56 PM.
