help with nitrous and th400
BTW at PGD's you were to buisy letting your girlfriend make Test and tune hits on a 150 shot to log any runs on my car...... same with atv's . good luck with all thise supper fast nitrous cars you have built
As far as your conserned you told me to not put a vic jr not put a top mount TB, not put a glide, not put a dana 60...I think te quote was youl be lucky if it goes 9's LOLLOLOLOLO
BTW hows not fasts old car doing.LOLOLOL
Your car had already been done the track on a rope and the tuneup was close (but it could have done with less timing) I knew this. Yours need to slowly bring the nitrous in earlier since every car was blowing tires away and watch the plugs F the knock sensor on HPTuners! Shed never been down track with a dry hit thats only been on a couple times on the dyno, and never left on gas with a car that went 1.32s on the motor. Kinda wanted to make sure it didnt flip over or pop it not checking its right first couple passes with a dry shot. Sorry!
I guess you melt "plugs" being rich Steve. You can lift ring lands way rich, but your not melting a plug with a strap like an AR92 because something is a little rich. Sure wasnt more than a little rich if it went 150 mph at 3600 lbs on pump gas. The quench was tight for the pump gas setup. Never was meant for you to throw another 200 hit on top of it later. The only thing you TOLD me to do, was leave the timing in it we had on the dyno because "Im always to conservative" It rattled at memphis - I said its hurtin - and it ate some plugs. I also said park it now before it did something catastrophic, or send it out the hard way. You said no way and if it was youd rather send it all the way out at least trying, I agreed with you its as good a place as any to hurt it. Pulled some timing out of it and it made it far enough and went quicker.
I never said dont get a 60. I said Id run 3.73s not 3.55s (dont get it twisted), so you dont have to leave off a hella hit to make it 60 ft. Cylinder pressure hurts stuff. At LSx race your car made 1 or 2 mid-low9 second passes and 3 days of blowing the tires away leaving full tilt and jetting it up along the way and then it got hurt. I made some suggestions wary of where it was going and YOU told ME "You had it under control" Im not going to argue with you about it. You told me point of Waynes DP so you have control over it, made it clear that what you wanted. The DP stage we saw 12.5:1 A/F and his motor end up hurt too. I dont think your putting anything on my shoulders because that aint rich nor because of a headgasket choice for a PG motor on a motor with 550 pills - it only need 250 to go 8s. You tell yourself so much you start to believe it. Ive always been willing to help, helped you get yours straight, then helped ATV get his straight, but when I help my girlfriend get hers straight its a big ******* deal. I helped all of you racing, you all burned up hundred hours on my dyno, no one else. My car sits apart, no one elses. None of you ever had one thing to say to me the timeframe your griping about now except for a smart *** comment maybe every now and then bout me being allowed out, but now Im such a mean MFer now that did sooo much to ya. Dont get it twisted, but whatever you want to say - grown ups move on let it go. Or at least have backbone to talk to the person before its such an issue instead of cluttering up someones post with nonrelated BS.
Wayne bringing up some completely unrelated **** is poor attempt to make someone look bad. Your just making yourself look bad reaching for stuff. When you have employees and do business for any length of time, **** can happen. Some people take care of it like myself, others pawn things off on customers etc etc. I can tell you this, no one has ever gotten a car back from me and was disappointed in how it ran. Hell when one of my employees dropped ball checking something, cust came in and said he knows there no warranty on performance parts - motor was out and all taken care of on my dime, put back together and made 35 MORE hp. Next time you think your airing out dirty laundry, check to see if its clean clothes
This is no better nonsense than yall in the other post. Reply with pertinant content and stop being eFag stalkers. You all have an obvious need to validate yourselves with the herding mentality. Ive never really needed to lean on 3 or 4 people to say what on my mind, but I guess theres comfort in numbers. Im done with all the BS from here on out, because it just doesnt mean nothing.Hvyhitter, contrary to what these guys might want to say now, I know how they work. A year or two ago I was explaining to them why Id do stuff to spread cyl pressures out, now the same guy who said "why the hell are we going to run a cam on 115-116 LSA" told me to do just that! I know what a 350 hit does, Shiz didnt have head issues on pump gas, and never did when he had 500+ hit on it either.
To the original poster, Ive had no problem with 346 or 400+ inch TH400 cars to make 150 rwhp abouts on 150 shot. Cant say what exactly is up with yours, but I can tell you whats has been done and proven.
Yes you can melt plugs pig rich and yyes you pop ring lands pig ritch clown. it also didn't help you insisted on the .045 quench when it should have been a 61. it sped up the burn causing way to much heat and melted ****.
BS on the car had been down the track. it went down the year before and made 1 149 mph pass. we had not got it down the trakc at all that year until the first pass on race day in memphis. even the T&T passes it didn't run right.
As the rest .send me the cliff notes. you get **** twisted in your ADD head and forget ****. THe reason we told you to stay out of it after while is you never wanted to help until it did something good. you kicked us out and told wayne ad i to sell the cars everytime they were not perfect. you never helped figure anything out just wantyed some of the glory! You didn't help me with puimp gas or going 8's other than some dyno time and were even on that since i helped build your shop! Stop bringing my car up in your posts. build your own car.... hell ash would never of went faster than 9.89 if she wouldn't of finally listened to me on the vic jr.
You want ot keep saying you did this and that. Jeff if it wasn't for my ,waynes, brents,chads and matts wallet what would you have ever learned? hell ashley would have never brought her car to you if it wasn't for me and wayne! you don't have to admit it everyone around GB already knows! Even ashley knows.
IT was never about helping her. I helped her a ton ,so did Native. It was about we would help her and you and when it came time for us to go racing our "tuner" never had time...... Good luck with going to races with you ash and grandma..... Well see you there. well be the ones going rounds!
Dont get it twisted
It was more than a little rich if it lifts the ring lands.
After it lifts the ring land oil gets in the cyl. and **** the flame up and it melts stuff. (plug tips first). So you might think it was lean or it had to much timing but if it lifted the ring land it was TO rich and thats what hurt it.
Dont get it twisted
You told me point of Waynes DP so you have control over it, made it clear that what you wanted. The DP stage we saw 12.5:1 A/F and his motor end up hurt too. I dont think your putting anything on my shoulders because that aint rich .
Here is some more info for you.
You can not tune a 3-400 shot with 1 wide band.
if it was at 12.5:1 truly then it would have melted on the first pass.
1st pass it went 9.8 @ 135 ... we took 6lbs. of fuel pressure out (because our tuner wasnt at the track, he was up his girls *** until she wanted to come the 2nd day.)
2nd pass with 6psi out it went 9.3@145 (dont think it was lean do you?)
3rd pass took out another 2psi fuel ... 9.2@147 (must be really lean now
)4th pass took out another 1 psi fuel .... 9.1@148.... thanks for your help
Hurry up and get this junk out of here, I need to get to Ashleys is all we heard.
We helped you build the shop and install said dyno so a few hours on it I think would be fair.
I never said you were mean (that would be gay) I said your a ***** whipped ***.
We tried telling you but you think it was a joke or a "smartass comment".
You dont answer the phone, you dont return calls and after you dropped his car off the lift you didnt even have the decency to call him and tell him, you send him an Email? WTF ?
Now the same customer wants us to finish the car because you have had his $10,000 for over a year with NO results.
I got nothing better to do at work then to **** on you all day buddy.
So next time you get on delivered be sure to tip him well, he may be the next "super tuner"
PSI
hey i figured id let you guys know that olde silver heap of matt's that was at PSI for 69 years getting a motor and whatever. burns oil by the quart every week now. 370 whatever it is with a TH400 12bolt blah blah blah all that other **** and its like a tenth faster then when matt had it...
ps.. wayne just took a **** all over jeff.......
jeff lets get some **** straight, every hookup you have is because of us, the type of tranny/converter/fuel system/intakes/welder/headflower/camshaft doctor and the list goes on is because of us! 3 years from now you will be trying to run **** we did last year still bragging about how you built sick **** and your the greatest tuners with the one same wideband that has been kicked around the floor of your shop for the past 3 years, copycat clown! oh yeah I cant wait to see you at the track this year
Dont get it twisted
English please!
Let me explain how it works. Your SO smart you should already know this.
Dont get it twisted
We could not get you to help us at the LSX race so him Saying"we got it under control" is his way of saying *** you we got it.
You are? when is the last time you came over to help? 2years ago?
Why is your customer calling me crying about you?
That guy would have beat your *** if we were not there. Ya you fixed it but it took you 6 months. 6 months of him paying for his Vette that he could not drive because your shop cant install a cam.
Contary to what this guy says now, I know 4-5 years ago I was working on cars and choppers for the military and he was delivering pizza's.
[/QUOTI be DAMN
he just took a serious **** on him
LMAO Gotdamn Wayne..... now THAT was some ALL pro DEEP chit you just dumped!
You won't need to hit duh ******* for a week-
Choppin...... you get points drivin' the last nail.
**** should be a sticky on severe ownage-
Take it to PM's. Hopefully the mods will clean up the thread with my comments included because this **** sure is
You really added something to the thread, way to get it back on topic.
Back on topic.... Sounds to me like a tuning issues not a cam issue.
Stock motors should make better than 80hp on a 150 shot.
I didnt say his was stock I said a stock motor should make more that 80 hp on a 150 shot.
So the 150 shots you have dynoed only make 43 ft lbs. of torque?(thats what his made 80 hp and 43 ft lbs.)
My 150 dry shot made 125hp and 200 ft lbs. thru a th400 and 12bolt.
Like I said something is off, probably the tune up.
Shes the one in the 2007 pump gas mag. nice girl and good looking but not loose all your buddies good!
It was not ash's fault at all she told him plenty of times to go with us. This is on Jeff noone else!
Ha ha severe ownage thats it. I just dont get off sitting on the internet trying to make myself look cooler to other men in a circle jerk. They keep a herding mentality, if you dont think what the herd thinks, guess you not part of the herd... like anyone with a spine cares. Perfect example one of the guys offered one of the herd rockers for free so he didnt have to find a set to buy. Rocker needer brings up this crap again (apprently needs to convince himself by repitition) and because guy offereing actually sees both sides and must have said something that doesnt sit well in his stomach - they chose to post back up they still need a set to buy. LOL
ANother example: These three pairs of clownshoes spent years shitting up every thread about a local shop they all had bad dealings with (as in paid to put motors in they did themselves, paid for tunes for cars that I eventually had to learn how to do and did myself, had to pay out of pocket for motors after installs gone wrong - little different than me not "going with") Whats funny now is, they are taking those guys out to dinner, hanging out with them and are "boys" all the sudden. Flip flop much or just need new friends, or just need?
I mean sure I chose to spend alot of time with my girl, Shiz has large ***** and all but just not my style
I was 18 delivering pizza and figuring out what no one around at the time was, ATVracr is 30 something and does gutter helmet. Much more prestigeous position I guess. Who cares?
See I can the same type of comments but it doesnt add anything of substance anywhere. Id be just another fool trying to make a mute point in some guys thread. Anyone can come up with witty remarks, not to many spines round here I guess
I quit playing follow the leader in grade school. Maybe time for some of you all to graduate?Look - Shiz said he had everything under control and didnt want my help. After that his blew up, Waynes blew up. Now thats all my fault somehow lol. And somehow in other posts when it suits ya I didnt contribute at all for stuff a year or two years prior. Sounds funny take credit for what you want and try and make it sound like I left ya hanging for what you dont want. Dont have any desire to help any ungrateful people. And dont give me how weve all done **** for each other, we have, and a real man would be able to say thanks and thanks back and let it be done with. I can say thanks for your help and be done... can you?
NOZR1 is right NONE f this belongs here, mods shoudl lock it liek Ive said before. Right it down in your diaries and sleep better and call it a day.
