Nitrous Outlets Digital Dual Window Switch??
Old Sep 21, 2010 | 03:58 PM
Brad@NANO Direct's Avatar
I have used 2 of these on personal stuff, and installed some for freinds. All of them have worked with no issues. A must have for any nitrous system if you ask me.
Old Jan 27, 2012 | 09:27 AM
v84life's Avatar
How do you set the 1st gear lock out? I cant find an instruction download anywhere for this model
Old Jan 30, 2012 | 05:32 PM
Chris@NitroDaves
Guest
Posts: n/a
PM Your email and i'll send a copy over.
In the mean time....
Old Feb 3, 2012 | 04:45 AM
ls1 1990 VN's Avatar
So what happens if 1st is locked out, you hit activation rpm the 1st time then rpm drops through bogging, you stay in 1st to bring rpm back up, does it think it's now in 2nd and starts spraying?
Old Apr 14, 2012 | 09:30 PM
v84life's Avatar
No I think once you hit the activation rpm you have go all the way to hit the deactivation rpm set for it to think you shifted which should be up high so not to hit it easy if you spin a little and have to petal but once you catch again you have to run that gear all the way out and then it will spray next time you go wide open throttle at or above the activation rpm again.
