Nitrous Outlets Digital Dual Window Switch??
Old Apr 15, 2008 | 08:48 AM
96prplz28's Avatar
Default Nitrous Outlets Digital Dual Window Switch??
I am going to be ordering one soon, i was just curious to see how people like it and how easy it is to wire up and use. Thanks
Oh and any pics of it installed would be nice to.
Brett
Old Apr 16, 2008 | 12:11 AM
Nitro Dave's Nitrous Outlet's Avatar
Im suprised there are no post here yet. I know for af act we have sold well over 500 pluss units on just the board alone... Come on guys.. Give this guy some feed back...
Dave
Old Apr 16, 2008 | 12:18 AM
Beer99C5's Avatar
Big Fan of it here
Old Apr 16, 2008 | 02:02 AM
RedsrtAk's Avatar
Very good unit!!! Does everything you want....yet very easy to use.
Old Apr 16, 2008 | 02:06 AM
porksoda's Avatar
You don't need a WOT switch with this correct?
Old Apr 16, 2008 | 02:33 AM
Speed Density's Avatar
hashtagBMW
Correct, its TPS activated.
I have one, its in the glove box.
Old Apr 16, 2008 | 02:50 AM
porksoda's Avatar
Cool I have one myself and I am fixing to install it. Does the window switch wire straight to the TPS to get the voltage reading?
Old Apr 16, 2008 | 03:24 AM
camscam02's Avatar
for me i cant get mine to read full voltage for WOT and still displays a 0 on the display as for the third number
Old Apr 16, 2008 | 03:27 AM
Beer99C5's Avatar
You can disable the WOT input (if say you want a mechanical one), or program it to where you feel WOT is based on Voltage (it displays during programing IIRC). For Vettes w/ ETC the blue wire goes to the Blue TPS wire.
You can get the instruction set from the trick performance products website.
Here is a link to my wiring scheme
Beers Wiring Trick Performance Gauge and Window Switch
Old Apr 16, 2008 | 07:34 AM
99FRC's Avatar
Definite thumbs up from me! I actually sold my MSD digital so that I could reinstall this one.
99 FRC
Old Apr 16, 2008 | 08:16 AM
96prplz28's Avatar
Thanks guys. You can actually lock a gear out with this can't you? say first gear in an automatic? I did a search and all i found was the MSD window switch, and i know these hae been out for awhile.
Old Apr 16, 2008 | 08:49 AM
Beer99C5's Avatar
Yes, it bases it on tach sweep, first gear is counted as the window is met climbs to max RPM, then drops below the window, when it hits the start window the second time, it will activate (if 1st gear is locked out). Both stages can have a gear lock out.
Old Apr 16, 2008 | 10:07 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Which wire are you connected to.
When is tps mode the numbers will be flashing and sweep with pedal movment. up or down depending on apllicaiton.
If this is not happening check which wire you are on and the connection itself.
Rick
Old Apr 16, 2008 | 09:28 PM
camscam02's Avatar
Rick
I believe its the navy wire ran right off the throttle body TPS part(cant think of the name) lol
when it tps mode it blinks and reads 4.7 volts i believe but then still has the 0 on the display.... the nitrous works fine but just want to see the 1! lol
Old Apr 16, 2008 | 11:17 PM
00WickedRedTA's Avatar
Thumbs up
Absolutely an awesome window switch. I previously had the BMN, but it would never work correctly, and couldn't get much help with it, so I got the dual stage switch from Nitro Dave. Works like a champ. Definitely a good buy. Wired up in my glove box. I use a mechanical WOT switch though.
Old Sep 14, 2010 | 06:53 PM
darkhorizon's Avatar
Would this work if I wanted to lock out 2nd and 3rd gear from nitrous, and spray only in first?
Old Sep 16, 2010 | 09:16 AM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
No, you can only lockout gears before you spray, not after.
Old Sep 16, 2010 | 10:15 AM
Frans96SS's Avatar
If i was able to order some i would I need about 5.
Old Sep 16, 2010 | 02:51 PM
Chris@NitroDaves
Guest
Posts: n/a
You and many other's...The new version should be out here in the upcoming weeks.
Old Sep 21, 2010 | 03:46 PM
camarorat's Avatar
anthing different on the new switch?
