What timing for 175+ shot
Im planning on spraying a 175shot then possibly going to around a 190 shot about what timing would you run? I have a standalone system with straight 116 octane in there for my n2o fuel system. Currently ive been running around 26 degrees with no issues on a 150 shot. I plan on dynoing this friday and as long as everything checks out ok with the kit I may throw in the 175 jets and go from there.
Yea I got the timing tuner so im not sure if I want to pull another 2 degrees out or leave it. Lol there used to be 32 degrees I think on a 125 shot with no issues either but that 125 hit only gave me like 80-90rw this 150 hit gives me around 130rw.
I might back it down to around 24 degrees for the 175 hit im running straight 116 octane in my standalone so it should help. When I had my car tuned along time ago the timing was like 32 degrees so im pulling it with a timing tuner but my timing also isnt always 32 degress sometimes its like 28 on the log so therefore when the log reads 28 its probably around 22 because hp tuners doesnt pick up timing tuner info on the log.
Yea I think im gonna pull another 2 degress so that should give me 24 possibly less depending what grams per cylinder table the pcm runs in because sometime the pcm commands like 28 degrees.
