Help Fast!! Noids Not Clicking!
Old Apr 18, 2008 | 12:28 PM
Johnnystock's Avatar
Exclamation Help Fast!! Noids Not Clicking!
install is finished,heater working , but the noids are not clicking?? I think its because the FPSS(engine not started), I am right??
I'll be testing it the road soon..
Old Apr 18, 2008 | 12:40 PM
flash12t's Avatar
pretty sure thats the reason it needs to see a psi for it to spray .. but i would make sure both noids open at the right time before u test it on the road
Old Apr 18, 2008 | 01:50 PM
finally, the noids are clicking when the engine is running...
BUT a I have several problems runnning my timing tuner:
It wont adjust for upper RPM
and the engine shut down when the arming switch is armed????
Can it be that my pcm is tuned with diablo prog and my cutoff is set with a HPP??
I knew it would be a pain in the *** this timing tuner
