NX 200 shot 10.5:1 A/F
After having Chad at Greenlight tune my car he advised me that my A/F was kinda rich on the nitrous runs. 10.5:1 A/F. He suggested going a jet smaller on the fuel. I have a Nitrous Outlet TB plate and the recommended jetting size for a 200 shot is 78N 46F. I have a 41 jet, but think that might be too small. Am I correct? Is there a 45 jet made for the NX kit?
Any other opinions are welcomed, and mods in sig if you need to know.
Thanks.
Thanks.
That's the beauty of a wet kit. They should have any jet you want. I agree that you are way too rich right now. Take small steps, but I imagine you will end up with a 43 fuel jet.
Here is a spreadsheet I made from some info I got from Doc
It calculates Nitrous AFR for optimum AFR (according to Engine Management:Advanced tuning by Greg Banish 2007)
Enter the Black Text Info, the red is autocalculated.
Beers Spreadsheet
Guessing you should be 11.0-11.1 for about 650 RWHP on spray (if you trust Mr. Banish).
Beers Spreadsheet
Beers Spreadsheet
Beers Spreadsheet
Beers Spreadsheet
I can't load that spreadsheet either.
Right Click save as, its an Excel sheet.
From what Greg Banish is putting out yes.
Here is the formula if the sheet don't work (works for me and I am in the middle of the Indian Ocean)
AFR for Nitrous = {(HP NA/Nitrous HP) * Maximum Brake Torque AFR}+{N20 Shot Size/Nitrous HP)*7}
So
AFR in my case...
417 RWHP NA
On a 150 Shot 567 RWHP
150 shot
Maximum Brake torque AFR say about 12.8
{(417/567)*12.8} + {(150/567)*7}
(.73544*12.8) + (.2645*7)
9.413 + 1.852
AFR = 11.265
You are pretty much taking the % of where the HP source is:
One is NA
the other is the Nitrous.
and Multiplying it by the Optimum AFR for that source
NA is 12.8 to say 13.1
Nitrous to Gas is 7 (according to Greg Banish's Book)
then ya add em.
So
AFR in my case...
417 RWHP NA
150 shot
9.413 + 1.852
AFR = 11.265
One is NA
then ya add em.
Mine calculated that way works out to 11.06 which just sounds very rich - even though I am currently at 10.3 which are what the stock ZEX jets give you without playing with fuel jet sizes.
Thanks for the lesson though.
Beer do you think that spreadsheet is a bit on the rich side? It seems legit on the numbers and how they came about but just seems to be a little conservative on the rich side. How accurate would it be with stalled autos?
Is there a story there?
I plan on using it in May for tuning my system.
Banish is not the Wizard of NOS guy is he? (I have seen the wizard is a loon).
Doc professionally tunes cars in Jax and is an axid COS 5 Nitrous user, so being he pointed me in towards the formula, I am satisfied it good info.
Thanks.
Thanks.
You could lower the bottle pressure to ~800 and try the 41 then if its still rich up the bottle pressure.
I think a 41 at 900psi will be close or a 42/43 at 1000 1 jet size is a verry small change.
What octane are you using?
