confused on the interface still (timing)
Running a tnt wet kit with a 250 shot
If i set my iat to 158 per the tuner, i should be able to pull 8 degrees. But if i want to pull 10 what should it be set at? Also in the directions it says something about setting it to -8 on the correction table and that lost me??? Also if it says to set the retart switchs to 15 then that would mean all of them on correct? As well as setting it to 10 on the interface i would just put 2 and 8 switchs on right?
Your lucky with the Z06 having 8 degrees available in stock form. I believe us F body guys get 3 degrees. Of course if you have HP tuners or some other tuning software its easy to change.
Like take an ls1 motor on the table in the directions a 158 iat i believe with all switchs on will get you 8 degrees i believe how would you get more as it looks like 158 iat is the highest setting
Disclaimer: I have currently, nor in the past, no connections what so ever with HSW. I have only talked to them one time, to get a tracking number for products I bought with my own money from my day job.
Robert
