RICH Backfire?
Old Apr 23, 2008 | 05:35 AM
Johnnystock's Avatar
Default RICH Backfire?
Small backfires are popping from my exhaust end around 5000rpm with 75pill and after it bugs out. My fuel pressure gauge is reading 71psi and 70 at wot??
I'm wondering if its my unequal fuel/n2o lines after noids that came with kit causing this(lines where where inverted in the installation pic/guide from HSW)
wet kit single nozzle,fpss,tr6 36gap,timing tuner
my car is reading 11.2 a/f ratio and 12.4 at wot n/a on crappy diablo tune.
Old Apr 23, 2008 | 11:22 AM
SY732's Avatar
What are you saying? that it is rich after you let off?
What lines are unequal the lines from the noid to the noz?
If so how long is each?
Old Apr 23, 2008 | 12:45 PM
99FRC's Avatar
Excess fuel burning off during deceleration will cause popping (technically backfire) from the exhaust. Is that what you're experiencing?
99 FRC
Old Apr 23, 2008 | 03:11 PM
sy732- line from fuel noid to nozzle:15inch and 20 for the N2O side.
99FRC- yes, it surges and after it seems excess fuel is burning off during decelaration and pops from the exhaust. and 70psi of fuel pressure. 1050psi on the bottle.
Old Apr 23, 2008 | 03:49 PM
one thing I'm sure is this happened at 5000rpm with 2degrees retard and it happened later at 5800rpm with 3degrees retard...
maybe its detonation and after its backfire from exhaust because lifting throttle??
I'll check my plugs
Old Apr 23, 2008 | 05:37 PM
forget about the fuel pressure;my gauge is stuck at 70psi unplugged
Old Apr 23, 2008 | 05:46 PM
SlayerMaro's Avatar
Backfire is when fire goes through your intake...hence the "back" part of backfire.
You are talking about afterfire.
Old Apr 23, 2008 | 06:10 PM
I didnt know the existence of the exact term but its more like that
Old Apr 24, 2008 | 12:07 AM
SlayerMaro's Avatar
It's ok. But if this concerns you, I think a custom tune should help you out. Canned tunes work out for some people, but every car is different.
Old Apr 24, 2008 | 09:57 AM
I figured it out: FPSS is cutting off the N2O,so I lift throttle and the afterfire happens. I just need a fuel pump asap. Something that will hold up to 600rwhp, racetronix or dual walbro, I dont know.
Old Apr 24, 2008 | 11:00 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I would suggest the Racetronix kit.
Old Apr 24, 2008 | 03:26 PM
^ pm sent, tired of waiting for a good used kit.
Old Apr 24, 2008 | 07:47 PM
1969mach1's Avatar
A/F sound way off at WOT NA.
I'm running a hypertech tunner and my A/R stays at 14.6 sitting still or WOT
Old Apr 25, 2008 | 10:17 AM
14.6 seems on the lean side, I think around 13.0 would be nice
