2 stages
Old Apr 23, 2008 | 10:52 AM
my number 1 hater's Avatar
Default 2 stages
I am thinking of running 2 stages .... My first stage is dry... Has anyone ran a 2nd stage dry??? Or just a wet 2nd stage...
Old Apr 23, 2008 | 11:43 AM
BAKED's Avatar
I ran one wet and one dry last year. It worked great for me.
Old Apr 23, 2008 | 03:32 PM
Wet first stage???
Old Apr 23, 2008 | 03:41 PM
dlove's Avatar
anyone know the pros/cons of the following?;
1st/2nd stage
wet/wet
wet/dry
dry/dry
dry/wet
with the new NX dry maf kit coming out it will really make things interesting. I want to run it with my wet shot but i dont know which one would be better to hit first.
Old Apr 23, 2008 | 04:28 PM
1st/2nd stage
wet/wet
wet/dry
dry/dry
dry/wet
Mine is dry before the Maf , And i think a wet kit for the second stage would work .... MAYBE BOOOOM!!!!!
Old Apr 23, 2008 | 07:24 PM
Robert56's Avatar
Years of dry dry here, and now dry, dry dry with 1st stage DP. No real reason or benifit to go wet if your willing to upsize your injectors. That would be the only reason to do a dry wet, however, the cost to do a second wet you could do a set of injectors and buy a second dry nozzle...
Robert
Old Apr 23, 2008 | 08:18 PM
Robert
Dry dry sounds good.... Did you run 2 bottles with the dry dry setup?
Old Apr 24, 2008 | 10:04 AM
BAKED's Avatar
I ran it both ways, it seemed to work better hitting the wet off the line and then bringing the dry in after I got a few feet out.
Old Apr 24, 2008 | 09:49 PM
showoff's Avatar
i personally run dry/wet mainly because i'd just like to minimize the chance of fuel puddling and having a n20 backfire coming off the line since i spray it right out of the hole..so far so good
Old Apr 27, 2008 | 01:28 AM
Robert56's Avatar
No/yes, well what I did was tee two 15lb'ers together. you can run both stages off one bottle, one line if you like.
Robert
