Options for cheap remote bottle open?
Old Apr 25, 2008 | 08:49 PM
pHEnomIC's Avatar
Default Options for cheap remote bottle open?
I think that remote bottle openers are excessively priced and cant figure out why such a simple product is so much. Has anyone rigged up a diy setup? It seems to bea simple motor that mounts to the bottle. I could be wrong but maybe have something like a motor with stops or have some type of clutch material so it slips after the bottle opens.
Old Apr 25, 2008 | 10:22 PM
DRSITES's Avatar
If you mount your bottle in the spare tire compartment, you can use a light bulb remover that will reach up to the side of your passenger seat... then just reach over, twist, and voila' you're a cheapass with a ghetto setup! Lol, seriously though, look out for one used, they regularly go for 100-150 used on here.
Old Apr 26, 2008 | 02:34 AM
myfast70's Avatar
I got a brand new one on ebay for $120 shipped! (minus the swicth to operate, which I didn't need as I have an ashtry switch) Just check the calssifieds in all of the sections and you're bound to stumble on something.
Old Apr 26, 2008 | 08:36 AM
ThunderTruck's Avatar
I've been using Cold Fusion bottle openers I got off Evil Bay at a reasonable cost and they work great.
Old Apr 26, 2008 | 08:40 AM
streetassasin's Avatar
kid nap a midget and throw his *** beck there. The only expense is a box of cheeze nips and pacific cooler capri sun, just throw it back there every 2 days or so and your set to go
Old Apr 26, 2008 | 11:12 AM
brokenfly's Avatar
Old Apr 26, 2008 | 12:05 PM
1969mach1's Avatar
Its a window motor that screws in place of the round handle. then fab up a mount that can slip around the base of the neck so the motor doesn’t spin in circles. or use a ball valve as above. split the line and mount the valve by the drivers seat.
Old Apr 26, 2008 | 01:11 PM
DopeFedZ's Avatar
Free openers
Old Apr 26, 2008 | 01:13 PM
DopeFedZ's Avatar
I heard Oompa Loompas work well for this application
Old Apr 26, 2008 | 02:44 PM
caliswangin916's Avatar
it's a spal power window motor on top. about a $30 part. straight up valve openers like the zex would be easy to rig but not really worth it. nx has the new design that works for all types of valves. i have one and the design is great.
i have a zex opener for sale. $90 shipped. works fine. i have a new switch from an nx kit or i can give you a used bmw power window switch(which i also use in my car). you'll need power and ground wires.
Old Apr 26, 2008 | 04:04 PM
pHEnomIC's Avatar
Ill take it, pm sent.
Old Apr 27, 2008 | 10:25 AM
myfast70's Avatar
Here's another member who is selling an opener
Old Apr 28, 2008 | 04:35 PM
TFPracing's Avatar
My buddy uses a nitrous solenoid to open his bottle in his 5o. It has been working great for him for a few years now.
