New setup almost done.
Sounds like you should probably be over 600 with all the timing pulled, and I assume you'll hit it with a good 2 stages of at least 200 a piece.
Get the car into the low 1.3 60 foot range, and it's gonna go into the 7's, at a good 170mph if I were a betting man
Robert
I'm gonna order one this august, figuring I'll see it around chrstmas time
Do that right and you probably can pull the timing, roll that in with the progressive and hit it with 500 if you get it right.
I can see the car running sub 1.25 60 foot's if you get it just right, hell that should be able to do 1.3 on motor I'd think you've got to be able to make 700 at the tires or close to it with an n/a tune in it.
Good luck man, I think with everything you've built there that you will be the first and probably only 7 second nitrous lsx car out there.
It's gonna be a serious piece of hardware, that should be capable of an 8 second pass n/a I'd think, so to get to 8.20 won't be much of a problem I wouldn't think.
36 jet isn't that big really for something that's gonna be progressed in.
Are you going with a carb or sticking with the EFI. When I saw you're going with a 4500 flanged intake, I can only assume there's gonna be a dominator on top of this beast.
Exactly what I wan to try next year, dominator with a speedtech 2 stage plate. I'm just hoping that ET comes out with that intake like the one you had, even if it only has a 4150 flange on it I can get my fab guy to convert that over it's not a problem.
Next time you talk to Cary, see if he has any word on that single plane they were working on, I'm hoping it's something I can call and order that is available port matched to the ET 240's I'm already running, be even better if it was available with a 4500 flange, but I can live with the 4150. No need for the EFI bungs in the intake either, I change the intake, I'm going to a carb.
My fab guy said what he can do, is take a 4150 flanged intake, mill it out mill the bottom off the 4500 flange and tig in a 4500 flange in so it won't be any higher, and we can just port it/smooth it out so that it sits down at the same level that the 4150 does. So basicially, that intake you have there, it will look like that but without the piece between the intake and the flange, the flange will sit down flat on the intake. That piece between the flange and the intake, is where my soeedtech plate will sit
I can't wait, next season will be a learning curve for sure, but it will be alot of fun, and should have some good results. Noone's really done a full race carb setup yet, I'm sure I won't be the first, but it will be fun to have, people won't know what the hell I have under the hood, with a distributor on the front and a carb it's gonna get called a SBF probably a million times before anyone realizes what it is LOL.
Robert
