Which wire to use???
Old Apr 29, 2008 | 08:31 AM
96prplz28's Avatar
Default Which wire to use???
Which wire should i use for the keyed ignition 12 volts?? And am i correct on a 2000 pcm pin 24 dark blue wire on the red connector is the TPS wire?
Thanks Brett
Old Apr 29, 2008 | 08:49 PM
96prplz28's Avatar
no one??
Old Apr 30, 2008 | 12:52 AM
Quick96ss's Avatar
I was told to get the 12 volts from the fuse box under the hood!
Old May 4, 2008 | 10:23 PM
jeffstaples's Avatar
Thanks Brett
In the fuse block which is visible when you open your driver's door, there is an unused block labeled IGN. This is a switched 12V source. Run a wire/spade into it for your 12V Switched source.
Pin 24 in the Red PCM is your throttle positioning sensor.
Jeff
