Using Cold Gas??
Old May 4, 2008 | 08:50 PM
harlesjohn's Avatar
Default Using Cold Gas??
Is it good to have pretty cold gas? maybe a certain temperature? could you use this for regular driving and/or for the nitrous fuel mixture
Old May 5, 2008 | 06:28 AM
black01_WS6's Avatar
are you thinking of using a cooler of some sort? I just wonder if the energy to make the cooler cold is more than what you would recieve.
Old May 5, 2008 | 09:46 AM
harlesjohn's Avatar
it would be pretty easy... copper line with a canister surrounding it with a chamber that i can open and close t o put dry ice in it.. as the gas passes threw that spot it would get cold from passing threw. i know it would work pretty good but how good would it work. im thinking for nitrous, like a wet shot that wont matter.. i might have better results all motor
Old May 6, 2008 | 11:30 AM
JosephIV's Avatar
Fuel Injected engines run a lot more fuel pressure than carb'ed engines. I would think that your setup would need more tubing and a larger can. Just opinion.
Old May 6, 2008 | 07:19 PM
JL ws-6's Avatar
Race your car!
I have seen some old school guys do that, have a can that had probably 10 feet of metal fuel line coiled up in the trunk where the fuel came out of the cell, before it left the trunk area.
I asked about it, the guy I talked to said it was a solid .1 and 1 mph faster after doing it.
I dunno how much of that I believe, it is sound thinking that it would help but that much I dunno.
This was a 400 inch sbc powered 70 nova, if that matters.
