nitrous jet placement
Old May 4, 2008 | 11:54 PM
pHEnomIC's Avatar
Default nitrous jet placement
I have the hsw wet kit. I am not sure if I put the jets in the right place. I unscrewed the allen heads on the tb plate, removed the two black fittings on the sides of the plate. I inserted the jets in there, put the fittings back on and retightened the allen head screws. Did I do it right?
Old May 4, 2008 | 11:57 PM
jmill96Z's Avatar
No. Leave the fittings directly on the plate. Insert the barrel end of the jet into the fitting, then place the line on the fitting and jet. Hope that clears it up.
