Dangerous to run line inside?
Old May 6, 2008 | 12:35 AM
pHEnomIC's Avatar
Default Dangerous to run line inside?
I am a bit worried running the nitrous lineinside the car. Just feels that if I have a leak, i dont want the entire cockpit to fill up with nitrous. If i have a leak and im just cruisin i dont want to black out from nitrous inhalation.
Anyone have any input? gonna be coming down inside from the spare tire area
Old May 6, 2008 | 12:37 AM
Robert56's Avatar
I think the majority run the line inside, and being SS braided the chances of problems are slim. try to find one case of problems?
Robert
ls1408cp's Avatar
As long as you dont swing an axe around in your interior while you are drivng you will be fine with it inside.
Old May 6, 2008 | 09:10 AM
Chris@NitroDaves
Guest
Posts: n/a
I never had a problem with my nitrous line on the inside.
-Chris
Old May 6, 2008 | 09:28 AM
Fratsit's Avatar
Thanks for the laugh, man.
R/
Frat
Old May 6, 2008 | 10:14 AM
Hennytime's Avatar
itll be fine, my first kit i ran it in cabin, the current kit and the dp im going to run will be outside just to keep space inside plentiful
Old May 6, 2008 | 11:09 AM
Z06kern's Avatar
My lines are ran on the inside of both of my cars and I never have had a problem.
Old May 6, 2008 | 11:12 AM
Ls1Gummi's Avatar
Well correct me if i'm wrong; but if the bottle is gonna be in the car the nitrous line will be in the car at some point in time. Not trying to sound like an ***, i'm just saying.
Old May 6, 2008 | 02:36 PM
02NBMWS6's Avatar
My SS line popped inside my car once before and emptied a whole fresh warm bottle that I had only made one pass on into the "cockpit" of my TA with the windows up. I heard the hissing sound and was thinking "wtf???" It started during my burnout in the waterbox, and I figured out what it was by the time I made it to the line. So I just flipped my n2o arm switch off and I made a new best NA pass
I didnt notice any effects from the fume inhalation whatsoever. Maybe the interior isnt small enough?
Old May 6, 2008 | 02:51 PM
97rs4life's Avatar
I would run it under the car and not in the cab of the car. Just ziptie it along the bottom and tucked up and away from moving pieces. Not hard at all and better than having it in the cab. There is a grommet at the bottom of the spare tire area that you can run it through. Not hard
Old May 6, 2008 | 09:42 PM
smokeum99ta's Avatar
Robert
I had one blow on me. Very exciting in the staging lanes. People were running over with fire extingushers thinking I was on fire. Hard as hell to breathe when turning off bottle, nitrous really takes away your breath.
Old May 6, 2008 | 09:57 PM
StngKlr's Avatar
Hmmm... people breathe it at the dentist office everyday.
I have the line inside the car and wouldnt be worried about a problem occurring at any time. Thats just me though.
Old May 6, 2008 | 09:58 PM
RoDan's Avatar
get a blow down tube to be NHRA legal.
Old May 7, 2008 | 08:37 AM
Nitro Dave's Nitrous Outlet's Avatar
On most all my installs I run the main feed line inside the car. Just make sure the hose is not around and objects that may eventually rub through or puncture the hose. Also make sure there are no bare wires up agaist the feed line. If there are wrap them in wire loom. The hose will rub a bare spont in the wire over time. If the wire is a hot wire it will burn a hole through the hose.
Dave
Old May 7, 2008 | 08:39 AM
Ohhh,
If you run it outside the car. Make sure it is not against anything that will puncture or rub a hole in it. Also make sure it is up tite where it can not be caught on anything. make sure you do not crush it with a floor jack and make sure it is away from the exhaust.
Dave
Old May 7, 2008 | 08:40 AM
b00sted's Avatar
Wuh wuh wuh wuh wuh wuh wuh...
