What to use instead of Teflon Tape??
Old Apr 19, 2009 | 03:31 PM
SSdimension's Avatar
The tape worked in mine perfectly. Just got to do it right and there shouldn't be any problem.
Old Apr 20, 2009 | 08:26 PM
NVR_SPDS's Avatar
Originally Posted by IROC-Z28_CAMARO
I have a problem hopfully someone could shead light on. I have a HSW kit and some of the anodized fittings dont thread into the solenoids worth a ****. The ones that do when you go to remove them they rip all the threads and **** the fittings, WHICH ARE NOT CHEAP, should I use the brass ones instead? I am using the teflon paste as recommended by HSW.
Thanks, Josh
I dont think it helps, but all of my fittings are from HSW, and they all went together flawlessly (Used paste as well).
Old Apr 21, 2009 | 06:29 AM
IROC-Z28_CAMARO's Avatar
ant ideas then? I have tried 3 different manufactures along with HSW fittings and they all do it.
Any help will be appriciated.
Old Apr 21, 2009 | 10:24 AM
brandoz28's Avatar
i may have just had some bad paste, but i everywhere i put it leaked, went back with red locktite and never looked back. just hope i never have to tear anything apart lol
Old Apr 22, 2009 | 09:23 AM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
just a thought, i bet it would make disassembly easier if they were hot like after a long drive.....for the loctite guys
Old Apr 22, 2009 | 11:22 AM
02 BLK WS6's Avatar
Paste
No leaks here.
Old Apr 22, 2009 | 11:27 AM
TARZAN's Avatar
I've used loctite, tape, and paste, depending on what I had around the shop.....never had a problem with any of them.
-Will
Old Apr 23, 2009 | 08:38 PM
Strahley's Avatar
Nothing for AN, teflon paste for NPT
Old Mar 14, 2010 | 11:06 AM
bigboykilroy's Avatar
red loctite here as well.
