What to use instead of Teflon Tape??
Dave
Dave
Applying the tape correctly is the hardest part for people.
Hold fitting with end that screws in first pointing toward you. Wrap tape around clockwise. This way, when you tear off the end, and screw the fitting in, the screwing in action doesn't attempt to "unwind" the tape. Make sure the tape doesn't lay over the hole in the end, keep the edge of the tape even with the end of the threads.
Thanks, Josh
