a couple dumb questions
Old May 9, 2008 | 06:53 PM
Cya_Vtec's Avatar
Default a couple dumb questions
Ok i am looking to just run a 75 or 100 shot in my car, my car only has PSLT's TSP turndown and a ls6 intake. So will it even been safe with only minor mods?i know i am going to need to get a diffrent TB but i am looking at this kit and just need some advise and also whats the best window switch to use
HSW Sudden Impact 78mm EFI Wet Nitrous Plate Kit (78mm LS1 F-Body & GTO)
so please let me know
Old May 12, 2008 | 09:45 AM
021less's Avatar
why will you have to get a different tb???? Nitrous don't care what mods you have done to the car, it will work either way, bone stock motor, or built out the ***. 75-100 will be good on a stocker, but 150 will work too. If you use a dry shot you will have to upgrade your injectors though for sure anything over 100 shot. and as for the window switch, just check with the sponsers, they have some good ones.
Old May 12, 2008 | 10:24 AM
Mike@HSW's Avatar
your car will be fine running that sized shot. if you have a stock tune you wont even need to pull any timing. You might want to pick up a ported and polished throttle body, but as mentioned above you do not need to replace it.
