Check list before I spray
Old May 12, 2008 | 12:37 AM
pHEnomIC's Avatar
Default Check list before I spray
OK so anything i am forgetting before I spray tomorrow?
I have hsw 150 wet kit, rigged up for 75 shot atm.
-racetronix fuel kit to supply extra fuel
-tr-6s to run colder
-tune is spot on n/a
-shooting for 11.5 a/f on spray
-cars set to pull 5 deg timing @ wot when kit is armed
-purge
p series gauge with:
wot tps sensor
window switch
a/f shutoff (gonna set it to disable for anything out of 11 to 12.5)
progressive ( i think my first shot im just doing straight up)
Old May 12, 2008 | 12:59 AM
Ryan33187's Avatar
I think your fine without the fuel kit to run that small of a shot, but I'm not positive.
Old May 12, 2008 | 01:09 AM
pHEnomIC's Avatar
Car's already cammed making ~390-430 rwhp before the shot. Eventually I will be shooting a 125 or 150 shot.
Old May 12, 2008 | 12:06 PM
SY732's Avatar
Have you checked the noids? (what I do)
1. Do they both click (w car off and bottle closed)
2. Test the flow of the fuel side (use a gas can)
3. Use the smallest jet you have and test the AF with the bottle closed
4. Use small jets you know will be rich and test it a few times from differnt speeds.
Once everything looks good creep up on the jets keep dataloging, checking plugs and AFR/FP.
Old May 12, 2008 | 12:15 PM
SY732's Avatar
Does it have a time delay set for the initial lean spike?
Set delay for .5 and go down to .3 if you can.
Set the window for 10.0-11.7
