tr6's good for my setup
The Bull
Re: tr6's good for my setup
General rule of thumb is one step colder plug for each 75 to 100HP more than stock you are going to add/make. It's also fine to start out cold and work your way up. If you are too cold the plugs will foul out until you get up to the right heat range.
What's your setup anyway? Does this have anything to do with Nitrous or just the list of stuff you have in your sig?
The Bull
Ohhh, geez, dry, well good luck with the fuel part. The rule still holds, you may want to go with a plug that's one or two ranges colder.
Sure, those plugs will be fine.
And what's wrong with spraying dry? 100 shot dry should be no problem at all on in internally stock engine. In some ways it's safer than spraying wet.
