whats it going to take to go 8s
Old May 10, 2008 | 07:28 PM
SSPerformance's Avatar
Default whats it going to take to go 8s
i Went 9.50 @ 140.85 on 800psi bottle presure do to it was so cold out that day. Car went 1.40 60ft Converter is setup for the big shot 300ish. i was at a 3190 race weights car is 3150 now. Im runing a direct port setup uping the jets to a 250 hit then will be ading a 2nd stage of 150 to it.
Old May 10, 2008 | 08:43 PM
ssfast99's Avatar
was the 9.50 on both stagest because if not you should do it. get the bottle pressure up because 800 is way low. a 250 shot at 800 psi rates different when it is at 1050-1100 psi.
Old May 11, 2008 | 07:35 AM
The 9.50 was on a 150 hit. the bottle prsure was low it was 40* out that day my jets are based on a 950bottle psi
Old May 20, 2008 | 05:11 PM
anyone
Old May 20, 2008 | 05:38 PM
landonew's Avatar
well, try both hits. I mean that would be cheapest way. Will it get you into the 8s? Possibly, but you will never know until you try.
