Debating on what progressive controller to use?
Old May 20, 2008 | 07:33 PM
Lt1junkie's Avatar
Default Debating on what progressive controller to use?
Well here is my situation... I am going to be spraying on the setup below in sig... I have been reading up on the progressive controllers and have come done to, two that i would want to use.. I am only going to be spraying a 175-200 shot but i would like to leave out of the hole on around 50shot then gradually let it kick all in.. What would be the best and less headaches for what i am trying to achieve... I also am running my nitrous setup threw a MSD digital window switch, WOT switch, and Auto retard curtosy of MSD digital 6
The ones i found are the digital from FJO for $209
Or Nitrous outlets for $140
http://www.nitrousoutlet.com/catalog...del=84&dept=11
Old May 20, 2008 | 11:35 PM
Gimp98TNT's Avatar
I'm using the Mini FJO controller. Its worked well so far, i'm glad i got it since im adding a 2nd stage.
I guess if you want less headaches go with Nitro daves unit, looks like it has less features and you dont have to use a laptop to set it up.
Old May 21, 2008 | 01:43 AM
Quick96ss's Avatar
I run the NOS Launcher. So Far it is amazing. You have so many things you can control.
Old May 21, 2008 | 05:43 AM
DiabloFormula's Avatar
I'm running a NOS MINI controller and I like it alot, but that NOS Launcher looks like it takes the cake on anything else out there, only thing is it's pricey compared to the MINI.
Old May 21, 2008 | 05:51 AM
300bhp/ton's Avatar
none sponsor link
Old May 21, 2008 | 09:12 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
the 2 units you list above are bothe very nice parts.
The Nitrous Outlet unit gives you the ability to set the start % and ramp time only.
THe FJO is a 2 stage controller, Window switch, and TPS activation. It lets you program a curved ramp by either RPM or by Time. THe down side is it requires a laptop to make changes in between runs.
A third option you might consider is the NOS mini-controller (pn 15974NOS) it is also a 2 stage progressive, window switch, and TPS activation switch. It only does Linear Time based ramping but it gives you a ground output for each stage. This will be used to connect to your MSD's timing retard trigger.
Old May 21, 2008 | 12:53 PM
Eagle02's Avatar
I too am looking to add a second stage to my existing setup and have been looking at the FJO since I can replace my BMN window switch then use this one unit to control both stages from one box. No issue with the laptop for me as I'm running HPT @ the track anyways.
Here's the manual[/url] for the FJO, I'm going to start reading.
Now I just need to know how to begin setting up the 2nd stage - like when to enable it, what % to step it, what RPM to fire it from, etc etc etc... Then come the tuning questions...
-Eagle
Last edited by Robert56; May 24, 2008 at 12:53 PM. Reason: Remove non sponsor link
Old May 21, 2008 | 11:17 PM
SY732's Avatar
I run the simple Nitrous Outlet 140 unit it is nice and so easy to make changes.
Make one test pass on a new street and then tweek the settings in less then 2 seconds, I put it in the center counsel.
Old May 22, 2008 | 10:59 AM
Frans96SS's Avatar
I agree on the Nitrous outlet unit.... VERY nice products from them.... They are deff, ahead of the game when it comes to nitrous...
