A/f question????
Old May 28, 2008 | 02:44 PM
Ls1Gummi's Avatar
Cool A/f question????
I'm spraying a 150 shot on my car. I have a wideband a/f guage and i wanted to know what should my a/f ratio be at wot??? 14.1-14.7??????
Old May 28, 2008 | 02:57 PM
ATVracr's Avatar
Just a little richer than your WOT motor tune.
Check some plugs also to be sure your good.
Old May 28, 2008 | 04:40 PM
crewchef's Avatar
14.x won't make many passes down the strip. Not knowing anything else about the car I would say 11.5 +/- a little either way. What's your base HP w/out the spray and what does it run best at NA? Pulling any timing on the 150 shot?
Old May 28, 2008 | 05:27 PM
DopdBrd's Avatar
NA I am around 12.5 - 12.7
NO2 should be a little more like 12.7 - 12.9
Old May 28, 2008 | 07:00 PM
Ls1Gummi's Avatar
Oh ok. On motor i'm probably 420-430, and yes i will be pulling timing. Best time was a 12.3 with a 1.70 60 foot
Old May 28, 2008 | 07:50 PM
jetlag's Avatar
I hope you're not talking about Air Fuel ratio.....
Old May 28, 2008 | 07:54 PM
DopdBrd's Avatar
Oh no, was I told wrong? That is what a few people have told me is a good place to be.
I know I run around 12.5 - 12.7 NA because of my wideband.
Old May 28, 2008 | 08:08 PM
crewchef's Avatar
Better check your sources I didn't want to argue the point but darned if I would spray any stock bottom end LSx at AFR of 12.anything. Even if you get by with it (for a while) you're probably loosing HP because you're not giving it enough fuel.
Do a quick search on nitrous & AFR, I know there's been some good discussions on this before.
Old May 28, 2008 | 08:11 PM
01FbTaWs6's Avatar
IMHO run 12.7-13.0 on motor NA, and run between 11.5-11.7 on n2o up to 150, abit richer on the 200. This is also based on a GOOD tuner. I can run 13.0 on motor all day long and not detonate(knock) but I have alot of time in my tune, and the timing is damned near perfect.
Old May 28, 2008 | 10:15 PM
firefighting1101's Avatar
11.5-11.7 to be safe...you can lean it out more for some more power, but i wouldnt do it
Old May 28, 2008 | 10:44 PM
StreetLethal01's Avatar
I run 11.7
Old May 31, 2008 | 01:27 PM
Ls1Gummi's Avatar
Anybody else????
Old May 31, 2008 | 02:44 PM
DopdBrd's Avatar
I'll do that man. I haven't sprayed the car yet, but like I said I know I run around 12.5-12.7 NA.
Old May 31, 2008 | 02:49 PM
Tommyv8's Avatar
On a smaller shot, say 100, you can go a bit leaner right?
Old May 31, 2008 | 03:58 PM
ATVracr's Avatar
Rich is not safe when it comes to nitrous.
That is a lesson ALOT of people have to learn on there own so good luck.
Old Jun 2, 2008 | 06:06 PM
caliswangin916's Avatar
on a wet shot right?
Old Jun 3, 2008 | 06:31 AM
ATVracr's Avatar
Either one.
You still need the same amount of N20 and fuel wether its dry or wet.
Old Jun 3, 2008 | 02:44 PM
02PWTRZ28's Avatar
mine is about at 11.6 right now and thats right where i wanna be. im just running a 75 shot that is dry so i could be wrong but you want your afr to be between 11.5 and11.8 in that range is good.
Old Jun 3, 2008 | 04:56 PM
BOTTLEFEDLS1Z's Avatar
Why is that. I thought the added fuel would keep the cylinders cooler,thus preventing detonation..
I'm running 11.0 AFR on a 150
Old Jun 3, 2008 | 06:30 PM
ATVracr's Avatar
Fuel gets in the ring lands and when it fires off it will lift it, from there it will loose compression and alot of bad stuff from there on out.
dont ask me how I know.
What A/F does the car like on the motor?
12.0 would be alot closer and safer IMO but some people will tell you I dont know ****.
