Should I run my STS kit or nitrous???
Old May 30, 2008 | 06:13 AM
Ryans_pewter_ss's Avatar
Default Should I run my STS kit or nitrous???
I bought a sts turbo kit and was about to build a 408 stroker, should I spray 175-200 shot or run the sts kit? I need to decide so I know what compression to run. Its not a dd just pretty much a weekend, track car. Please help me decide.
Old May 30, 2008 | 06:15 AM
ATVracr's Avatar
Both!
Old May 30, 2008 | 06:50 AM
trans2000am's Avatar
good luck on 175 shot that would be really really nasty maybe like 50 to 75 just to launch the car,but hey try it and video tape it would love to see 10 pounds and a 200 shot that bitch would skeet skeet
Old May 30, 2008 | 08:17 AM
ATVracr's Avatar
Leave on the jug and ramp the N20 back as the boost increases.
Old May 30, 2008 | 08:56 AM
AlexLs1's Avatar
This is what I was going to say pretty much. Best of both worlds.
Old May 30, 2008 | 09:22 AM
so ya'll r sayin run both nitrous and turbo? I was wondering if I should sell the turbo and run nitrous or keep turbo and no nitrous, what kinda compression for both?
Old May 30, 2008 | 10:26 AM
Nitro Dave's Nitrous Outlet's Avatar
Running both is no problem. Build the car for Boost... The nitrous is just a pluss and compression will not matter for the nitrous you add.
Dave
Old May 30, 2008 | 10:59 AM
ok so a big turbo and a small shot will be fine?
Old May 30, 2008 | 11:48 AM
Yes sir...
Old May 30, 2008 | 12:27 PM
TARZAN's Avatar
Make sure you build a GOOD engine....and if you can, get the L92 (I believe thats the designation anyways) ARP Head Studs, accompanied by some thick deck heads.....
As they said, a 50-75 shot would help fix ANY lag issues you might find, with a larger turbo. Thats the way I went on my GN. I have a lil larger turbo, so there is a little lag initially....but I spray a 75 shot and cut 1.5 short times . Nitrous is like insta-boost on a turbo.....You could always put the NO2 on a hobb switch to cut off at like 5PSI or so.....Or, you could just be a badass, put an 88mm on it, and a 150 shot.
If you're gonna be a bear, be a grizzly
-Will
Old May 30, 2008 | 12:34 PM
ATVracr's Avatar
-Will
I like the way you think !
Old May 30, 2008 | 12:42 PM
TARZAN's Avatar
Well, its probably a bad idea...but I've got a GT45 and a nitrous kit awaiting install....either I'm gonna make a cool video with a fast pass.....or a cool video with a nice fireworks display
-Will
Old May 30, 2008 | 01:02 PM
LS2Camaro's Avatar
Go for both, even running a small shot will yield in large gains with a turbo. I will be throwing a 75 shot on my S85 turbo camaro, because 700rwhp isnt enough.
Old May 30, 2008 | 02:36 PM
i want over 700 if possible. where can i find a bigger turbo? I was gonna sell the kit but all of this has me thinking! If i run the nitrous what about a meth kit? could it be used or is all i need is the bigger turbo?
