how much timing to pull threw hsw interface
Old May 31, 2008 | 05:43 PM
BRADP's Avatar
Default how much timing to pull threw hsw interface
i have a lt1 and 125 dry hit. how much timing should i pull with the hsw interface on my lt1. thanks for the help
Old Jun 1, 2008 | 04:48 PM
BRADP's Avatar
come on sombody has to know how much timing you can pull for a 125shot
Old Jun 1, 2008 | 04:50 PM
jmill96Z's Avatar
I would pull 5 degrees
Old Jun 2, 2008 | 01:50 AM
02PWTRZ28's Avatar
i have the dry plate kit for mine and i use the interface controller and i belive its two degrees for every 25. so you would be at 6 degrees at 125. i believe thats what i read in my manual.
Old Jun 2, 2008 | 03:57 AM
jmill96Z's Avatar
I've always done 2 for every 50. Each car is different though.
Old Jun 2, 2008 | 09:26 AM
Nitro Dave's Nitrous Outlet's Avatar
Depending on how aggressive your tune is you need to pull about 4 degrees...
