Another JoeyG and Oaks N20 Install (pics)
Thanks, guys! Figured I had better spend some time over here. Lots of Nitrous info.
![](http://img.photobucket.com/albums/v445/throck1/Nitrousenginepassside.jpg)
![](http://img.photobucket.com/albums/v445/throck1/Nitrousdriverside.jpg)
Still have some wire and mount cleanup to do in the back:
![](http://img.photobucket.com/albums/v445/throck1/Nitrousbottlesetup.jpg)
![](http://img.photobucket.com/albums/v445/throck1/Panel.jpg)
Fantastic help from Beer, Steve C., Matt @ Harris, Shannon, & Dynotune (window switch & ash tray panel).
Congrats Jeff! Looks awesome dude....let me know if you need any fittings or anything. With all the crap i have, surely i would have just about anything you would need.
There is a false knock happening (2-2.5 degrees) at throttle tip in and it lasts from 3.2k to around 4.4k then goes away
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Well I guess the 97 degree inlet temps wouldn't help also. Looking over the logs looks like there was some more to be done with this kit Timing and fuel correction.. Jeff and I will fix the little problems and hopefully make some more runs shortly. Picked up 10hp and 3tq peak power and 25ish hp/26ish tq in the midrange tweaking the stock tune. Car only has a blackwing and some 2.5" catback system on it also.
Sounds as if your making progress. It must be some false Knock? Running 17/18° timing is pretty low, unless your at the 250rwhp or above level (a 22/24° setting would be better for your overall hp level)? So, getting the timing figured out, IMO, adding some back for the smaller hits, would add to the overall power numbers in the entire curve. That's the level I have for a combined 6xxrwhp shot, 18°. Anyway, I am sure you will get things sorted out, and keep us updated. That lean spike at the end of the run may be an indicator that your your running out of fuel pump, and/or as simple as a filter? 90% DC is nothing to worry about at all, and a short ¼ mile run will have no real effect on Inj longevity. But if upgrading fuel system anytime soon, maybe throwing a set of injectors on would be a good move.
Robert
Robert
Robert
Robert
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
One other note is this was my buddies import shop dyno. I dynoed my 416 on it and made like 498hp/488tq. Then went to another local dynojet 2 days later, same tank of 91 oct gas, same tune, same weather conditions and made 546hp/532tq
![1poke](https://ls1tech.com/forums/images/smilies2/1poke.gif)
