mandatory items for a 300+ hit or more
Things I thought right off the bat was 4 bolt splayed mains, GOOD rods like at least oliver or lunati..... Also are aluminum rods required or preferred at this level???
Head studs or head bolts??? O-ringed block required???? And speaking of the block are you guys that are running these giant shots running at least 1/2 filled blocks...
What about fuel systems? Is 10 AN Feed and 6 AN return enough? Two nitrous bottles or one????
I just wanted to start a discussion that people could maybe save money or motors picking the right parts from the outset. I know what I have in my motor and it was built to handle 300+ worth of spray but I want to find out what you guys think...
most people dont realize what you have to do to spray a 300 shot....you will need a rearend, tranny, driveshaft, built motor, stand alone system, and some suspension to hook up a 300shot.
But he is a STRONG supporter of automating everything using the XFI box.... And he's behind dry nitrous systems and even running wet plates dry.... So right now my nitrous system is shaping up like this. A Nitrous Pro Flow 2 stage inline plate (not the X-plate) with burst panels. top bar is stage 1 and is jettable up to 250hp.... bottom bar is up to 350hp and is stage 2.....
My plan right now is since I have a 600A Weldon that is good up to like 800hp or so I'm going to be walking the fine line on the 300 hit..... So I'll run only 1 stage at first probably like a 175-225 shot and run it dry with my 50lb injectors after Theo builds me a new pulsewidth map that XFI will switch over to when the nitrous is flowing. He uses only power adder exclusive and not power adder additive tables.... We'll see how that runs and if we decide we're gonna use both stages then i'll swap to a 2035 Weldon gigantapump and 160lb injectors...... Nothing else needs to change since i have 10AN feed and 6AN return. those should be good for my power levels.....
I've just always wondered what top level sprayers put in their motors to withstand 400-500 shot systems..... I would imagine at a 400shot you've gotta have aluminum rods at a minimum.. the shock alone would probably bend a steel rod.... no matter who made it...
That's how I managed to run 9.70's on a bone stock IRS.
I'm loving this set up so far over the old/wet dry combos
If your tuner is suspect your wallet needs to be really big.
