solenoids sound like a sprinkler system
sounds like a bad ground to me. try grounding them out to a different location and if the problem persists maybe some of the guys on here can direct you elsewhere. what are you using for system activation? window switch? progressive? WOT switch? if the ground isnt the issue i would start checking into your activation method.
