LS1 Carburetor Nitrous help Needed ?
Old Jun 10, 2008 | 07:15 AM
kirk1989's Avatar
Default LS1 Carburetor Nitrous help Needed ?
I am wanting to run a 150 shot on my 6.0 ls6 just wondering what timing curve should i use in the msd ignition module. (right now i have curve 6 in it)
Old Jun 12, 2008 | 02:15 PM
Solid Motorsports's Avatar
I'd try MSD's web site or tech line...Maybe even the N2O manufacturer
Old Jun 12, 2008 | 10:28 PM
jay_lt4's Avatar
you want the msd 6010 box so you can program your own timing curve and nitrous retard,,, all the msd pills have 36* timing wot,, that is way too much for a normal lsx engine,,, put nitrous on to of that an you will be melting parts
Old Jun 13, 2008 | 04:28 PM
b00sted's Avatar
Yep. You can't run those pills with the LS1 motor(and get it to run right/make power)....Let alone add nitrous to the mix. I don't know what the MSD/Edelbrock engineers were smoking when they came up with those timing curves...But I want some.
Get the 6010 box and program your own curve. Usually around 29-30* total timing with stock heads. Then pull 2* per 50hp sprayed via the Nitrous Retard function. It's simple to setup.
Old Jun 14, 2008 | 02:32 PM
TJ's Avatar
TJ
while i agree you shouldnt spray with that much timing, how do we know that it hasnt been researched to run more timing on a carbed ls1.
efi, fuel is sprayed in, only air is sucked into the motor.
on a carb, the fuel and air is drawn in.
this could very well make a difference in the timing setup.
on motor, i have played with curves, and different timing, and the car runs the same et/mph from 28-36 degrees.
ON MOTOR.
im going to use the retard for the nitrous to be safe.
Old Jun 14, 2008 | 05:44 PM
b00sted's Avatar
The stock curve in the 6010 would spike the timing from 29 to 36 somewhere around 4800 rpm. It caused the car to break up. Then I dropped it to 29 across the board and it ran mint.
36 is too much from what I've seen.
