interface addes fuel when not at wot?
That's how I understand it anyway and mine seems to be working correctly.
When wired correctly it won't add fuel or pull timing until all other trigger events have occured, i.e. WOT, RPM window, FPSS and nitrous arming switch on. I was out tweaking on VE and MAF settings today. I did several WOT passes and interface never pulled timing or tried to add fuel.
Robert
Just posted as an example to confirm for you that the interface won't give you any issues when driving around NA even if (when) you decide to open it up.
