guys who wired their os5..
Old Jun 8, 2008 | 11:47 AM
ls2 bait's Avatar
Default guys who wired their os5..
2 things. 1 what pins are what on the relay at the pcm in the pic below
second what wire would i need to t into in this diagram to get it to activate when the n2o is switched on?
Old Jun 8, 2008 | 12:43 PM
Beer99C5's Avatar
I just wired the Red pin 56 to a switch, when grounded, COS 5 is active
Old Jun 8, 2008 | 08:09 PM
ls2 bait's Avatar
so basiclly all u did was put a toggle switch on pin 56 that goes to ground? that seems pretty damn easy then ill just need to find space for another switch.
Old Jun 8, 2008 | 08:13 PM
Beer99C5's Avatar
Yep,
I believe you can put the wire off the PCM to the + side of the noid, when the noid fires, its grounded...no need for a switch.
I like having control over it, so I use the switch.
Old Jun 9, 2008 | 05:07 PM
ls2 bait's Avatar
Originally Posted by Beer99C5
Yep,
hmm i kind of like that idea. id actually like to put it on a switch with my fuel pump. damn i need to learn some electronics.
Old Jun 9, 2008 | 06:31 PM
BOTTLEFEDLS1Z's Avatar
All that I did was, once I turn on the system and the relay sees ground, the PIN 56 gets it ground from this as well. No need to run a toggle switch..
Old Jun 10, 2008 | 09:11 AM
ls2 bait's Avatar
so then which pin on the relay would i need to run a wire off of to pin 56? it would be the relay that controls the solenoids right?
Old Jun 10, 2008 | 10:10 AM
Yes, that way when you arm the system and it has ground, so does PIN 56
Old Jun 10, 2008 | 09:15 PM
ls2 bait's Avatar
so which one will i tee it off of?
Old Jun 14, 2008 | 10:23 PM
ls2 bait's Avatar
bump
