VGauge Problems? Help!!!!
Old Jun 14, 2008 | 09:58 PM
2002RamAir's Avatar
Default VGauge Problems? Help!!!!
Finally got everything all wired up. Im using a progressive controller and I have all the wires for the guage wired right and everything is all programmed right according to the instructions... Well the hour glass on the screen of the gauge will not go away... From what I read the hour glass shows up when nitrous is used and the gauge is updating the bottle level... Anyone have any idea what could be wrong??
Old Jun 17, 2008 | 11:18 AM
Chris@NitroDaves
Guest
Posts: n/a
Your best bet would be to contact Trick about the problem.
http://www.trickperformanceproducts.com/contact.htm
-Chris
Old Jun 17, 2008 | 11:24 AM
Beer99C5's Avatar
I had the same issue.
I really do not use the Bottle percentage (yet) and made the mistake of setting it full and then telling it it was used up with no shots being fired.
Short term fix is go configure,
Set the shot size to 0 for both stages
Then tell the bottle its full.
Hour glass goes a way, but your 100% stays at 100%.
I believe then its a matter of just setting it back up to the correct shot size on full bottle, spray away and then tell it when its Empty and it will reprogram and work...
Old Jun 17, 2008 | 11:39 AM
Beer99C5's Avatar
perhaps the polarity on the configuration is reversed as well...its thinking because based on the polarity it still thinks your spraying.
Old Jun 17, 2008 | 11:46 AM
2002RamAir's Avatar
Got it... It was the polarity.
