HELP! Huge nitrous issue...
Old Jun 16, 2008 | 06:10 PM
PyroFox04's Avatar
Default HELP! Huge nitrous issue...
Today I went to get on my nitrous, and when I do, the car sounds like it's backfiring/misfiring badly, and I experience a significant decrease in power. I'm throwing no codes, aside from O2 codes that have been going off and on since I put O2 sims in the rear banks.
The car runs otherwise fine without nitrous. What the hell is going on?
Old Jun 16, 2008 | 06:21 PM
860 Performance's Avatar
I assume this is the dry kit listed in your sig?
If so, have you dyno'd it, or had it ever worked properly?
Old Jun 16, 2008 | 06:23 PM
PyroFox04's Avatar
Dry setup, 125 shot into the air lid.
98 Camaro Z28, LT headers/TD exhaust. Ran nitrous fine till today...and no, never dyno'd it, but it ran smooth on the road.
Old Jun 16, 2008 | 06:27 PM
As you probably already know, dry kits are sensitive to nozzle placement and even angle. Did you happed to tighten or loosen the nozzle any?
Old Jun 16, 2008 | 06:29 PM
PyroFox04's Avatar
Well, I disassembled it to clean the MAF yesterday, but I put everything back together exactly the way it was...or I hope I did.
Old Jun 16, 2008 | 07:31 PM
Ah, the nozzle is probably turned a bit from where it was.
Old Jun 16, 2008 | 09:32 PM
PyroFox04's Avatar
Somehow I doubt that...I've been taking it apart and putting it back together for a long time to regularly clean the MAF/change pill sizes, and I've never had an issue even remotely close to this one.
Old Jun 16, 2008 | 10:15 PM
99345hp's Avatar
you might want to go find someone that can read you a/f ratio in real time while hitting it. I have a snap-on vantage tool that I use to read all my sensors, but I dont know what u have available to you. I am not a nitrous expert, but from my fuel injection experience it sounds like a lean misfire to me.
Old Jun 17, 2008 | 12:40 AM
Johnnystock's Avatar
when my FPSS was cutting the n2o, I was having backfire at the exhaust on a wet setup(rich backfire)..I dont know about dry but get a read on your a/f or it could lead to disaster.
