From a spark plugs point of view
Old Jun 18, 2008 | 04:47 PM
shannon's Avatar
Default From a spark plugs point of view
This is near perfection correct? This is pulled right after a nitrous run...Somewhere between a 150-175 shot....
Old Jun 18, 2008 | 05:27 PM
koolrayz's Avatar
Cant read it with those pictures
Here is a great link on reading plugs
http://members.uia.net/pkelley2/sparkplugreading.html
Old Jun 18, 2008 | 05:37 PM
shannon's Avatar
Thanks dude....Thats the **** right there!
Old Jun 18, 2008 | 06:26 PM
ATVracr's Avatar
hard to see it good but it Looks rich to me.
Here is a good pic of mine on a 350 shot......
Old Jun 18, 2008 | 06:29 PM
ATVracr's Avatar
Is that a TR6 plug? if so you might want to try a step colder.
Old Jun 18, 2008 | 06:38 PM
shannon's Avatar
Yep that's a TR6....Man I went to the BR7EF's and melted a plug....Yea I know I dont understand it either but I have had no problems with the TR6's...
Old Jun 18, 2008 | 06:59 PM
ATVracr's Avatar
If I melted a 7 I would have went to an 8 and backed the timing off more.
What timing are you running on the motor? how much do you pull for the 150 shot?
Did you drive to the track on those plugs? they have alot of color on them for 1 pass.
Old Jun 18, 2008 | 07:43 PM
shannon's Avatar
Im running 24*....Those are the daily driving plugs....They just got a lot browner after I leaned it up....They were all black and sooty...I have an 11.5 AFR on Nitrous, I wanted to lean it up a little and went up on the N pill...This is what I got...It used to be black where the brown is now.....
Old Jun 18, 2008 | 07:57 PM
ATVracr's Avatar
24* when your spraying? how much do you pull for 150 shot?
It needs to be leaner and it will go faster.
put a new plug in right before the pass then kill it at the end of the track and pull it... best way to know for sure whats going on with it.
Old Jun 18, 2008 | 08:00 PM
shannon's Avatar
Yep 24* when spraying...No KR on the dyno or 3 1/4 track runs while data logging...I keep the same tune so I dont have to switch for motor/nitrous
Old Jun 18, 2008 | 08:31 PM
ATVracr's Avatar
Did your knock sensors go off when you melted the plug? They aint gonna save your motor.
What timing does the motor like N/A?
I pull 6* out for 150 shot. Which is 19* total for me.
Old Jun 18, 2008 | 08:48 PM
shannon's Avatar
It starts KR'ing at 28* on motor...
Old Jun 18, 2008 | 09:12 PM
Jpr5690's Avatar
I Run 28-29 Na And About 20-21 On A 150 Shot
Old Jun 19, 2008 | 05:40 AM
ShiznityZ28's Avatar
You guys have to stop using knock sensors for timing tuning. just put the timming in that runs the best MPH on the motor ATV is right the plug should not be a 6 and if you melted a 7 put an 8 in and pull more timing. lack of timing will not kill it so put 19-20 in it and get the A/F correct. cut it down like atv did and post that pick but you can't drive around on the plugs or it will mess up the reading. Put a a fresh set of 8's in and cut it off at the stripe switch out 1. then do it again and pull the 1 with a single pass and one with 2 passes. cut them down and post them up. Id bet A/f needs to be 12.2 at its richest. maybe 12.5
