can i spray a 150shot?
Staying conservative on the timing is one easy way too keep your ringlands happy and motor together. In the OP's case, at the BARE MINIMUM I'd use 100 octane to help against detonation. If you're running full timing (or if you've had a tune you could very well be running more than stock timing) you're asking for trouble with a shot that big on a stock bottom end IMO. Either pull some timing or throw in some 100octane/octane booster.
