Need some Timing Tuner help
I'm trying to simply pull 6 degrees of timing while spraying, run my normal timing when NA. I'd also like to set up the window switch from 3200 to 6300. Not really concerned with screwing around with the delay function yet unless it really is best to set it up with some delay.
Like I said, I'm f'ing lost here. If someone can point me in the right direction or walk me through it I'd appreciate it. These directions that I downloaded aren't making any sense whatsoever.
