NXL nitrous install HELP!!!!!!
Old Jun 29, 2008 | 09:56 PM
cbra-klla's Avatar
Default NXL nitrous install HELP!!!!!!
Finished up my install today....I had a couple of pounds left in the bottle so i figured i would try it out. when the nitrous engages, the engine flutters and bogs horribly as if it is just opening the fuel noids...it takes about a second to clear out, then runs fine...i know my bottle wasnt full, but i got the pressure up to 950 before i sprayed it...i have never felt a car flood that bad when they run out of bottle either...i have had and been around several nitrous cars before, but never a direct port setup...
I know i need to purge it first also... it bogs every time the nitous is engaged.
i am curious to know if maybe the fuel accumulator is giving me any problems, but shouldnt it not matter long as the fuel maintains the same pressure?
i dropped the bottle off tonight to get filled..ill try it again tomorrow with it full to see if it fixes the problem..
any other ideas if that doesnt help???
Old Jun 29, 2008 | 10:38 PM
Hennytime's Avatar
low pressure im sure killed it, also purge it to get the instant hit
Old Jun 30, 2008 | 03:00 PM
CODE4LS1's Avatar
That kit needs the accumulator so it doesnt fall flat on is face. I have it on my NXL kit.
