Nitrous Kit.... anything missing?
Old Jul 4, 2008 | 10:53 PM
Lt1Porsche's Avatar
Default Nitrous Kit.... anything missing?
I am about to place my order for the following parts and would like to know if you see anything missing from my setup.
LS1 Stock 78mm EFI Plate System w/10lb Bottle
Automatic bottle heater
Purge Kit
Fuel pressure safety switch
Nitrous filter
NHRA Blow off fitting
Blow down tube
Digital dual stage window switch with built in TPS activation and gear lock out feature
Nitrous Outlet '98-'02 F-Body Console Switch Panel w/Guage
860-F-Body Bottle Mounting Bracket
NGK TR6 Plugs
Anything missing?
Oh and does the digital dual stage window switch allow you to control rpm activation and deactivation? If not what would I need?
Old Jul 5, 2008 | 12:50 PM
Lt1Porsche's Avatar
Anyone?
Old Jul 5, 2008 | 01:01 PM
Todd157k's Avatar
Nope.. and yes.
did you double up on the heater though? The 860 is an automatic heater.
Old Jul 6, 2008 | 11:39 AM
Lt1Porsche's Avatar
Dont think so I just copied the part number off of their website. I noticed that while I was writing all my parts down but the website says its a 860-F-Body Bottle Mounting Bracket which is the bracket that mounts within the spare tire area.
Old Jul 7, 2008 | 08:55 PM
Nitro Dave's Nitrous Outlet's Avatar
Your list looks good. The digital windowswitch give you the activation RPm as well as the deactivation RPM. It also gives you a TPS activation and traction controll. It also controlls up to two stages.
Dave
