Should i move the nitrous bottle?
Old Jul 6, 2008 | 12:36 PM
GOR1LA's Avatar
Default Should i move the nitrous bottle?
When i bought the car the guy had it where the ttops are, but i kinda want to put the ttops plus have the bottle. Its a 10 lbs bottle and i was wondering if it would be better if i change the location and put it in the spare tire location? Also im not sure what way the bottle is suppose to tip. towards the valve or toward the bottom of the bottle. I'm pretty sure its toward the bottom but just making sure...Also, should i invest in one of those auto valves for the tank?
Thanks
Old Jul 6, 2008 | 01:16 PM
Nick@HSW's Avatar
There are plenty of places you can mount the bottle. Another option, if you are dropping the fuel tank anytime soon is to mount it on the shelf. Or inbetween the back seats...that way you could just turn around and open the valve whenever you need it. Just make sure the bottle is mounted so the the **** is slightly higher than the bottom of the bottle. This is to ensure the pick up tube pulls the liquid nitrous rather than vapor. If you are looking for a remote bottle opener, take a look at ours...it has two quick pull pins for easy removal for refills or incase an emergency requires you to manually close the bottle.
http://www.harrisspeedworks.com/shop...cat=272&page=1
Old Jul 7, 2008 | 08:52 PM
Nitro Dave's Nitrous Outlet's Avatar
We offer a special mount for the spare tire area or you can simply bolt it to the inner fender well.
Dave
Old Jul 9, 2008 | 04:08 AM
GOR1LA's Avatar
Will That Bottle Mount Be Able To Hold/fit A 10lb Bottle In That Small Area? Thats A Really Good Idea When I Get Some Time I Will Really Look Into Getting That. Great Idea!!
Old Jul 9, 2008 | 08:54 AM
camar0corey's Avatar
860 spare tire mount is a nice piece. So guess it depends if you want to run a remote bottle opener, or only use it at the track, or back seat as mentioned for easy opening.
I had devilish thoughts cross my mind when I had my passenger seat out. I almost said why not and just stick it there. Shotgun! No go sit on the floor in the back.
Old Jul 9, 2008 | 10:02 AM
Chris@NitroDaves
Guest
Posts: n/a
This is with the spare tire mount used
<-- Image linked to product on website
-Chris
Old Jul 9, 2008 | 12:48 PM
krazy4's Avatar
Good bracket. I vote for putting the bottle in the spare tire compartment.
Old Jul 9, 2008 | 05:32 PM
508Stroker's Avatar
I had that bracket in my 3rd and 4th gen. Works great.
