keyed 12 volt soure
Old Jul 16, 2008 | 09:40 PM
99puterss's Avatar
Default keyed 12 volt soure
were does the keyed 12 volt soure go, sorry if thats a dumb question.
Old Jul 16, 2008 | 09:52 PM
jetlag's Avatar
Pink traction control wire.
Or there is an open spot on the fuse box, you could use one of those add-a-link fuse tap things. A couple dollars are an autoparts store.
Old Jul 16, 2008 | 10:30 PM
99puterss's Avatar
were is the pink wire located
Old Jul 16, 2008 | 10:36 PM
shoemike's Avatar
the fuse box on the side of the dash has a slot for switched 12 volts. IGN
Old Jul 16, 2008 | 10:43 PM
99puterss's Avatar
so that 12 volt can be connected to anything
Old Jul 16, 2008 | 10:46 PM
SuperSlow02's Avatar
If its on a switch, it dosnt have to be a keyed source....just make sure they are off when the car is off and not being used...
Old Jul 16, 2008 | 10:56 PM
99puterss's Avatar
okay so i can connect that to the cigarette lighter " the one that looses power when car is off"
Old Jul 16, 2008 | 11:01 PM
Black99TransAm's Avatar
cigarette lighter will blow a fuse. just go directly to a empty location in the fuse panel.
Old Jul 16, 2008 | 11:08 PM
99puterss's Avatar
okay thanks
Old Jul 17, 2008 | 12:43 AM
Speed Density's Avatar
hashtagBMW
Red - Constant Source
Pink - Switched source
Old Jul 17, 2008 | 03:09 AM
jetlag's Avatar
Orange is also constant...
99puterSS, I used the pink traction control wire that is on the switch itself.
Old Jul 17, 2008 | 10:15 AM
Nick@HSW's Avatar
I always wire them directly to the fuse panel. As someone said above, just run to the auto parts store and pick up a add-a-fuse and you'll be all set!
Nick
Old Jul 17, 2008 | 12:00 PM
99puterss's Avatar
okay thanks
