Homemade nitrogen push setup. Pics
-2-4 tenths (for 150-200hp shots)
-consistency
-back to back runs
-tech support
-correct jetting
-hassle free
-parts and service
For someone running 550hp of nitrous $689 dollars is nothing for what you recieve.
Larry
Larry
Ok, our systems are made to be matched on a 1 to 1 ratio so if you have a 10lb bottle you will need a 10lb NANO bottle. So you cannot use a 20lb NANO bottle for 2 10# nitrous bottles.
The reason being is that the regulators are variable rated. So for instance you have a 20lb NANO bottle on a 10lb nitrous bottle. When you spray the car the 20lb NANO regulator thanks it needs to cover the nitrous bottle dome space of a 20# nitrous bottle not a 10#. So therefore you will get too much flow. If you have a 10# NANO bottle or to small of a NANO bottle hooked to a 20# Nitrous bottle the recovery rate will go way down due to the oversize of the nitrous bottle.
The lower price kit will be out for sale, i want to say within the next month.
They retail at $465.00, if you buy a kit they are around $400-420. The used ones sell for around $300-$350.
We have had great luck with the nano systems and have sold a great number of them. We were in the process of designing a system that works similiar to what the nano accomplishes when we seen advetisments for the Nano. I ordered one and personally tore it apart to look it over. Minus the the Bottle valve not been cleaned of metal cut off debrees I was impressed with the quality. So I looked further into becoming a dealer for Nano.
Since then we have sold a great deal of there systems and during the process of carring there product there customer service has been great. For that reason I set our project aside and started focasing on other new products..
I say Great Job Nano. You guys developed a great product that someone can order put on there car and get tech support to help make sure they are on the correct path during tunning.
As with anything there is always cheaper ways of building something. However just because its cheaper does not mean its better.
We will continue to be a proud dealer for Nano Nitrous!
To the originator of this thread. Looks like you did a great job putting together a cost affective way of something that is currently meeting your needs. Good job! Thank you for taking time to share...
Dave
Dave
Well said Dave
Larry
I simply cannot fit a 20lb bottle in my car, but definitely "need" 20lbs of nitrous... so I'm left with two 10lb bottles (or four 5lbs or one 5lb and one 15lb but those options are all retared).
Ill get back with you
Brad @ NANO
I look forward to the release of your new system. Thanks for taking the time to reply.
