Question on a purge system
Old Aug 25, 2003 | 10:44 AM
Smok'n Red American Muscle's Avatar
Default Question on a purge system
Hey, I have a 00' Trans Am w/ a NX 100 wet shot system. I bought a purge system w/ 2 outlets. I have the outlets coming out of the Ram Air in the hood (I have a cold air induction, so only the purge system is in the vents). When I purge, the nitrous comes out of the outlets but you cannot see it at all. I was wondering if the purge system is bad, or I'm I purging a small amount or could it be installed wrongly. I know it can be done b/c I have seen it work before. Thanks a lot, I appreciate it.
adam
Old Aug 25, 2003 | 11:47 AM
Nitro Dave's Nitrous Outlet's Avatar
Default Re: Question on a purge system
Are the two line sticking alittle past the grid?
Old Aug 25, 2003 | 01:06 PM
ApacheDrill's Avatar
How long are you purging it for? Sometimes you need to hold it for a few seconds to see it purge.I know that sounds dumb but thought id make sure.
Old Aug 25, 2003 | 05:02 PM
The two nozzels are not coming out from the grill, they are behind it. And I did try and purge it for a longer amount of time and the bottle was at a good running temperature.
Old Aug 25, 2003 | 09:36 PM
Robert56's Avatar
Outside temp and humidity can cause a no show when you purge.
Old Aug 26, 2003 | 02:30 PM
ok, thank you, i appriciate it.
Old Aug 27, 2003 | 12:47 AM
1BadAzzWS6's Avatar
What was thre bottle pressure. You should be right around 1050. If the bpttle pressure is too low or close to empty you won't see anything, but you'll still hear it.
