Nitrous A/F
Old Jul 31, 2008 | 09:15 PM
00cls1camaross's Avatar
Default Nitrous A/F
what is ideal for nitrous a/f ratio?
Old Jul 31, 2008 | 09:28 PM
Todd157k's Avatar
11 to 11.7 ish.
Old Jul 31, 2008 | 10:21 PM
PistonHead's Avatar
Perfect timing. I was just about to search for the same question !!
Thanks,
Brad
Old Jul 31, 2008 | 10:52 PM
i heard if it is running too rich it will burn ring lands. 11 is safe not to burn these. A friend of mine runs a 150 shot on 10.8 A/F ratio.
Old Aug 1, 2008 | 06:57 AM
ShiznityZ28's Avatar
Theres alot of factors but for 100-200 shot on stock ported heads and good gas 12.2-12.4 is safe. stay out of the 10's
Old Aug 1, 2008 | 10:07 AM
Ruckus46Gt's Avatar
az doesnt have good gas
psr wanted my af around 10.5 i swapped jets and moved it to 11.5. 11.5 is ideal
Old Aug 1, 2008 | 12:55 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Your friend should be fine at that a/f - he could actually go to the mid 11's as Todd noted. 150 shot you want to worry more about going lean. I have never seen a car lift ring lands with a 150 shot but I have seen melted tips on plugs. Yes if you are running a 300 or 400 shot then all bets are off but most people are not running that size shot.
Dean
Old Aug 1, 2008 | 01:04 PM
Nitro Dave's Nitrous Outlet's Avatar
I shoot for a 11.8 on aversage size shots. When I get to the larger shots such as 250 pluss I shoot for 11.5
Dave
Old Aug 30, 2008 | 06:53 AM
vette_c6's Avatar
are these AFR number for DIRECT PORT WET SYSTEM ?
i mean people who use Plat system should do that ,, but when you use direct PORT
fogars for each Piston ( fuel + Nitrous )
do u have to do the same ?
Old Aug 30, 2008 | 08:41 AM
AutoRoc's Avatar
My 150 tune takes me from 12.5 on motor to 11.5 all the way down the track with the hose flowing...plugs look good, runs like a champ, pretty good gains on the track also.
