Digital RPM Window Switch(MSD#8969)
Old Aug 7, 2008 | 10:46 PM
BOLO's Avatar
Default Digital RPM Window Switch(MSD#8969)
@WOT, shift points are@6800rpm. Rev limiter is@7200rpm. At what rpm should I set the nitrous to turn off at? I will be setting it to come on@ around 3000 rpm.
Old Aug 8, 2008 | 06:46 AM
SuperSlow02's Avatar
depends on if you want to spray through the shifts. I had mine shut off before the shiftpont at first and didnt like it. So know i spray through my shifts...
Old Aug 8, 2008 | 09:21 AM
Dabeztz28's Avatar
If you dont want to spray through the shifts id say atleas 200rpms before your shift points.
Old Aug 8, 2008 | 04:41 PM
BOLO's Avatar
If spraying through the shifts, can I just set the juice to cut off @100 or 200 rpm before the rev limiter?
Old Aug 9, 2008 | 06:23 AM
Dabeztz28's Avatar
Yes. That way it will stay spraying during shifts, but it still below your revlimiter (which you shouldnt be worried about hitting if your tranny is fine)
Old Aug 9, 2008 | 09:12 AM
sleeperstyle's Avatar
if you spray through the shifts the trans probably won't last. why do you think i have a th400? because i don't like OD and lockup? you may have better luck than me but i doubt it.
to make the trans last a little longer (i had a 4l60e last for a while spraying) have the spray shut off like 50rpms before the shiftpoint. you'll hardly feel it. it takes some logging, you may have to use the mph table more than the rpm table (hptuners) to get it perfect because when the n20 shuts off the rpms will drop down and the n20 can surge on again before the car shifts- but imho it's the best way to do it. takes trial and error to get it right but worth it in the end.
Old Aug 9, 2008 | 09:38 AM
KBG's Avatar
KBG
I have a stock bottom end and a built 4L60 and I have shift points at 6600, limiter set at 6700, and the spray shuts off at 6400
Old Aug 11, 2008 | 11:12 AM
98mysticZ's Avatar
mine shuts off at 6400 shift at 6600 m6 here
