Micro switch help!!!!!!!!!
Old Aug 8, 2008 | 01:09 AM
Freddyrdzls1's Avatar
Default Micro switch help!!!!!!!!!
i have a tnt f1 kit and i m doing a two stage nitrous ...
well the question can i use one micro switch for two nitrous kits...
but i want to have have two different switches to arm them
is there such thing as having both kits with one micro switch with different arming switches..
or would i need two micro switches to be able to arm them separately
i looked around and didnt find any similar threads..
thanx please reply or pm me thanxxx
Old Aug 8, 2008 | 01:26 AM
jetlag's Avatar
How about a dual stage digital window switch?
One arming switch, but you can set a different RPM for each kit to kick on?
http://nitrousoutlet.com/catalog/pro...product_id=964
Old Aug 8, 2008 | 01:39 AM
myfast70's Avatar
You should be able to use the WOT switch for your ground connections to the relay's for both kits and then use your arming switch for the positive side of the relay. Should be a pretty simple setup.
