Propane and Nitrous?
we need more guys experimenting with it.
ive been reaserching it a little and it seems like it give good gains for people who tried it.
I hope to get a propane injection kit for my turbo soon. and might do a propane and nitrous shot later.
the page you listed wasa good one, it tells the jet sizes the guy was using and the results.
i wish more nitrous companys would research propane.
Restricted User
Lets see, a nitrous/propane Direct Port.....Al, what are your thoughts on this, if any???
Finguring out the jet size might be a pain.'
How much do you think the pressure will effect the output? Like now with a wet kit, the fuel is a constant pressure (same as fuel system) but the Nitrous loses pressure (unless you have a push system or a heater) when your running, therefore making your AFR a little richer as you head for the top end. Now, the propane may do the same would it not?
One propane tank will last about 10 bottles of nitrous, depending on the shot size. So you don't have to worry about propane pressure drop for quite awhile.
CAT3 I dont know anything beyond what we have discussed here. I will just be working through the specifics when I do it. It will likely be a few months. I still need to hook up the power I have now.
Restricted User
Oh boy. I was thinking of building my own DP, and then seen this. So naturally am interested in using propane as the fuel..dont see why it wouldnt work, just a little more test and tune. Might have to break new ground here if I can t find anyone with info on it already.
Charlie.
Charlie.
Here is another link for a kit I looked at before. Its geared toward the forced induction crowd. http://www.dynamicracing.com/customer/home.php?cat=34
for the subject on direct port propane.
It really isnt nesecary. the reason you use dp is to distrubute fuel and nitrous with out puddleing and equally. since propane is a gas, there is no chance of puddling so the standard throttle body injection will do.
as soon as my cable modem is back up at home, i will put some links up that i found on this. the viper shop i found will sell the kit to add propane to any kit, but the only jets they have used are NOS jets. so you would have to try different jettings to get a good a/f ratio.
If you go to LS1.com and search the nitrous section for propane there are a few threads dealing with it. You can probably get alot of info there. Then if you have any questions let me know and I'll see if I can't answer them.
#32
Also, propane is widely used on big yachts and other large boats. I know, cause thats what I do during the daytime. If you shop around at the marine supply stores, they sell the remote bottle openers for propane bottles. The usually run in the $45-$60 range. They are used to shut the propane systems down on boats, when they are not in use or in an emergency situations. Just make sure you get a 12V model, cause boats will run either 12V or 24V.
#39
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#40
and not only that, you could run a bigger shot than your fuel system can support since the fuel is coming from the propane bottle. and we cant forget the higher octane rating.
i agree that propane being a gas will help with distribution but nitrous is a gas when flowing through your intake but how come the front cylinders still get more nitrous than the ones in back? propane should be safe than gasoline on a large wet shot but it is certainly no replacement for direct port injection and there are still pluses in a direct port application.
annother thing to consider is that since you have to jet richer on the fuel side when using propane there willl be less room in the cylinder for air/nitrous. now, im not sure about this but.. since the propane is being compressed just like the nitrous is, it should be very cold when released and since colder air(or gas)is denser it may take more time to get the jetting right because your jet size may let a certain amount of propane through just like fuel but the propane should be much colder and therefore denser which would mean your actually letting more propane into the cylinder and running richer.
i was playing around with the idea of propane for a while but i just ordered my NXL today and since the only thing i would need fuelwise to run it is a bigger pump i dont think i'm going to be experimenting with propane untill octane becomes the limiting factor in my setup.
