New MicroEDGE nitrous controller from HSW!
Old Aug 12, 2008 | 02:13 PM
Nick@HSW's Avatar
Default New MicroEDGE nitrous controller from HSW!
Harris Speed Works Inc. is pleased to introduce to the world the first smart window switch. The MicroEdge controller packs a powerful punch in the features department without draining the bank. With features such as: Dual Stage Control, A/F Shut Down Switch, and multi-gear lockout, the MicroEdge is a technology leader in the nitrous industry. But those aren’t even all of the features that are included! The MicroEdge was also designed to work on any rpm signal, from individual coils/coil on plug to crank position sensors. RPM signal can also be obtained by using the fuel injector or tach output signal.
Feature Set of The MicroEDGE:
RPM Window Switch – Only operates the nitrous system within a set “window” of RPM.
TPS Activation Switch – Only operates the nitrous system at (WOT) wide open throttle.
Dual Stage Control – Allows for the use of multiple nitrous kits to be run off of one (1) window switch. IE; multiple stages which can be used with different RPM & TPS values.
A/F Shut Down Switch – Nitrous system(s) will shut down if a lean condition is detected by either a wideband O2 sensor or narrowband O2 sensor. The MicroEdge will also shut down the system if an overly rich A/F is detected (wideband sensor only).
Lean Out Delay - The MicroEdge controller can be programmed to not shut down the nitrous system for a determined amount of time if a lean condition is detected. Great feature for those small lean spikes upon kit activation. This feature can be adjusted up to 10 seconds in .05 second intervals.
Multi-Gear Lock-Out – Can be configured for both stages and can lock-out multiple gears to optimize traction.
Time Delays – Activation of kits can be delayed for up to 10 seconds in .05 second intervals.
Pedal Delay – Delay(s) used to re-gain traction if the system is activated and the gas pedal is let off due to wheel spin and then re-applied. This allows for momentum to be built prior to re-activating the nitrous system(s). Both stages have their own pedal delay which is adjustable up to 10 seconds in .05 second intervals.
Nitrous Solenoid Delay – Delays the nitrous solenoid from being activated for an amount of time after the kit is activated. This helps to cure any lean spike issues that are pre-existing in the system.
Display – Built in LCD display can show RPM, A/F Ratio (mV for narrowband), TPS voltage, Battery Voltage, and Arming Switch Voltage.
File System – Up to three (3) files can be saved within the MicroEdge unit for quick and easy flipping between runs.
We will be running a PRE-SALE on these units until the end of August. If you have any questions concerning the features on the unit or its operation please feel free to shoot me a PM. Thanks!
Old Aug 12, 2008 | 02:24 PM
MYSTIC-1SC's Avatar
this looks like a really nice product
Old Aug 12, 2008 | 03:04 PM
JoeyGC5's Avatar
How much are these?
Old Aug 12, 2008 | 03:11 PM
Ihasfip's Avatar
Definately we need a price.
Old Aug 12, 2008 | 03:35 PM
bad6as's Avatar
pm me a price on this too!! god im glad ive waited as long as i have
Old Aug 12, 2008 | 03:41 PM
Beer99C5's Avatar
Very cool!
How big are they? I am thinking some C-5 guys may want to fit one in one of my C-5 ashtray panels
Old Aug 12, 2008 | 03:44 PM
~RedLineLs1~'s Avatar
Thats awesome. I likey.
Nick@HSW's Avatar
Oops sorry guys I forgot to include the link to the pre-sale. http://www.harrisspeedworks.com/shop...cat=308&page=1. Price is 129.99 for the pre-sale which ends at the end of August. Thanks!
Nick
Old Aug 12, 2008 | 03:45 PM
Nick@HSW's Avatar
Originally Posted by Beer99C5
Very cool!
I'll shoot you over some dimensions later today!
Nick
Old Aug 12, 2008 | 03:53 PM
YellowToy/A's Avatar
Does this unit have a output when the solinoid it is active? This would be used to drive a relay when active.
Old Aug 12, 2008 | 05:24 PM
Nick@HSW's Avatar
Not quite sure what you're asking. Do you mean does the display show that the system is activated? If so, yes it does.
Nick
Old Aug 12, 2008 | 05:25 PM
SuperSlow02's Avatar
now...that is freakin nice
Old Aug 12, 2008 | 07:40 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm probably going to have to get in on this pre sale.
Old Aug 12, 2008 | 07:53 PM
Cliff's Avatar
I love this!!!!!!!!!!!!!!!! I'm in.
Old Aug 12, 2008 | 09:33 PM
Z-RATED94's Avatar
Good thing my birthday is this month!!!!!
Old Aug 13, 2008 | 07:15 AM
I want to know if the is a relay driver that can be used to switch in a resistor for the IAT sensor. This would be a wire that would go to relay and control it. That way I can set PE and take timing out when the system is active by setting the IAT.
Old Aug 13, 2008 | 07:38 AM
JoeyGC5's Avatar
You can use the second output to trigger a relay a few hundred rpms below your nitrous on rpm and satisfy both goals.
Old Aug 13, 2008 | 08:21 AM
bk04cobra's Avatar
GET IT BROTHA!!! How else are you gonna make me see tail lights
BTW...i'm probably coming up home this weekend..cookout at kayla's moms new house on Saturday..come when you get off work
Old Aug 13, 2008 | 08:49 AM
sixvi6-camaro's Avatar
Damn.. The HSW Interface and MicroEdge would make one hell of a sick and adjustable combo. I know where I'm buying my nitrous kit this fall!
Old Aug 13, 2008 | 09:34 AM
Kelly.'s Avatar
wanna make me a deal for this and a brute force ls1 plate kit , pm me a price
awesome looking product!
