Direct Port Question
Old Aug 14, 2008 | 11:34 AM
web8745's Avatar
Default Direct Port Question
What is the smallest shot you can run on a direct port set up?
Want to run a 100 shot but not sure.
And if so what size jets would be required.
Old Aug 14, 2008 | 11:46 AM
Nitro Dave's Nitrous Outlet's Avatar
You can run a 100 on a directport. However if you are running it on the factory fuel system at 60 psi the orfice size of the fuel jet will be very small.
Dave
Old Aug 14, 2008 | 01:38 PM
Chris@NitroDaves
Guest
Posts: n/a
100 HP @ 60PSI
20n
12F
Old Aug 14, 2008 | 02:13 PM
Mike@HSW's Avatar
do you have intentions of eventually going larger? im just curious why you want an elaborate system for such a small shot. running a low psi standalone would make it much easier to run that small of a shot
Old Aug 15, 2008 | 01:32 AM
Sammyboy's Avatar
He must....plus nothing beats the looks of a direct port.
Old Aug 15, 2008 | 10:05 AM
web8745's Avatar
No i have no intentions of going any bigger than say a 125 shot .. Just believe that a direct port is the safest way to go.
What do you all think?
Old Aug 15, 2008 | 10:21 AM
Mike@HSW's Avatar
Yes technically it is the path to the most even distribution of nitrous and fuel to each cylinder. It would be WAY overkill for your intentions with it though. If you wanted it for show car intentions then so be it, but it’s really unnecessary for your plans. I would recommend a plate kit in my honest opinion; our 360 degree perimeter spray pattern offers great distribution and that is what I would suggest you use.
