what fuel pressure?
Old Aug 15, 2008 | 06:46 PM
Tee1up's Avatar
Default what fuel pressure?
When running n20 150 wet shot, should I run the same fuel pressure as I do NA or different. And if different what should it be? I'm using a racetronics fuel pump.
Old Aug 15, 2008 | 07:39 PM
fstphx's Avatar
Same- Jet for your shot-
Old Aug 20, 2008 | 03:39 PM
ICRAZY6's Avatar
Same fuel pressure at NA. Just make sure the jets are correct for the shot you want. The aftermarket fuel pump will keep the fuel pressure constant and not dip like the stock pump tends to do.
